configure the new mdx 3.0.0.0
  • configure the new mdx 3.0.0.0
    when I open the mdx configuration how and where do I add my variables for the steering wheel controls. Like the voltage is between 3.39 - 3.97 for the mode button. vol up button is 1.0- 1.08 and so on. Do i add them in the at the fusion configuration xml document, under logic? It doesnt give me ''statements'' and then the ''if'' like in the old program. Just logic and then all ''logging'' and all ''variables'' Also when I open the mdx configuration I cant open configurations that I saved when I closed the program. When I click on the folder icon above thats says ''open a configuration file'' it does nothing. It like I start back over again every time I open the program, it tells me to add the brain and analog input
    https://www.facebook.com/hinnantdesign1
    This is why I havent released MDX. The configurator is like 20% to 30% done. The main program is fully functional. Use Notepad or any XML document editor with the code provided in your other thread, and save it.
    You cannot open, because there is no open function implemented.
    And what you want to do is in the logic section of the configurator which I am only programming right now. (just updated the config thread).
    I posted the link just to help you out and get you a more stable, easier program that worked while the configurator was being programmed. Once it is released, both will be functional and included in a single installer.
    1.9in x 2.9in -- 47mm x 73mm
      I should add, if you do actually encounter an error with the configurator, please post in the configurator thread: http://www.mp3car.com/vbulletin/soft...a-testing.html
      That way we can consolidate everything.
      So far there have been no errors, so it is looking good so far.
