Error when loading FCC UberMDX
  • Error when loading FCC UberMDX
    I have the ver 2 of the old software working GREAT! Now wanted to try the UBERMDX version.
    Running Direct x 9.0c
    From Debugger:
    Could not load file or assembly 'Microsoft.DirectX, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    Sound Stage
    Eclipse|MTX|Infinity
    ...Fixed reinstalled Directx 9.0c
    Sound Stage
      Good to hear!
      1.9in x 2.9in -- 47mm x 73mm
        Getting a similar error to that above.
        On Vista. File not found - FusionCOM.
        Drivers are installed OK. Any ideas?
        Thanks!
          When did you download the installer?
            Also now with speech control, make sure you have the .NET 3.5 Framework installed.
