Unable to save some fonts
  • Unable to save some fonts
    Hello
    This is my 1st post Iíve been sandbagging on the side reading. Iím impressed with the effort everyone is putting into helping & improving this product. Iím using the MDX for the 1st time and have just hooked up the brain fusion & updated the Fusion control centre (automatic update) and used the ninja to make my 1st trial XML file. When I go to save it is telling me that ďUnable to save some fontsĒ. Iím using the ninja with 2 temperature inputs and 3 outputs. I have found many folders with font files in and have made sure that all font folders have the same fonts available in all. Perhaps Iím missing something in the how to tutorials Iíve been reading. Thanx
    Originally posted by Dagwood View Post
    Hello
    When you save your configuration file, are you then moving it somewhere else? And then when reading it back, are you reading the moved version?
    The reason it doesnt load the font is because it cannot find the font.
    if you can post the beginning part of your xml file, I can tell you where to look for the actual font file.
    1.9in x 2.9in -- 47mm x 73mm
