Shifting icons on Configurator menu bars
  • Shifting icons on Configurator menu bars
    are a distraction and disorienting. . . unless you're displaying a submenu. Title comes up next to the cursor, anyway.
    GadgetBandit
    Here you go:
    I just uploaded an update that should give you guys access to this icon. It will create a settings file just for the configurator. Currently the only option is to disable the animated icons, but more options will probably be added as time goes on.
    1.9in x 2.9in -- 47mm x 73mm
      Thank you. As I ween myself from Configurator, can you recommend a free, xml freindly editor?
      GadgetBandit.
        GadgetBandit.
        Notepad...
        XML is just text, so anything that can open text, can open xml. You can do it in Word if you want to. I use Macromedia Dreamweaver.
          Dreamweaver! yesss! Color coded!!!
          Sorry, the word "free" should not have been in my question. Nothing is free.
          Please consider starting a library of code snippets for us newbies. The flash example you did for texting was great. The code from that taught me a lot. I can now set the temp range in my greenhouse from the logic in your example.
          GadgetBandit
            Also I am not sure why I didnt think of this, but I use Visual Studio a lot to do xml since I change it on the fly and all the programs are developed in Visual Studio.
            The Express versions are a free download from M$ but waaaay overkill for just xml. But they work nice and have good indenting/autocomplete that sort of thing.
            I use the Pro version so I dont know what XML stuff is included/disabled in the Express version but I like Visual Studio.
