Configurator and invisible instances
  • Configurator and invisible instances
    Hi
    I have a small problem when using the configurator.
    I am developing a skin but suddenly all my instances becomes invisible when I open a page to edit the graphics properties.
    When I open the page for edit everything is white, the background, and all the instances are gone, I can edit the instances by left clicking on them but no matter what I do I can not get them visible. (also played around with the z-order to no avail.)
    Running the MDX everything seems normal, when looking at the page in the overview window without opening them they look ok…
    Does anyone have a god idea on how to fix this?
    TIA
    Olds69
    When you move your mouse it should redraw. If it is not, then there is a GDI+ problem somewhere. Do you have any sort of weird hardware setup?
    1.9in x 2.9in -- 47mm x 73mm
      No strange hardware as far as i know :-)
      2 months old Dell laptop, also tried it with my old laptop and the same happens there.
      (both run XP)
      I should mention that the skin is quite large, with 4 pages and 5-8 multi images on each, 270 images in each multi image...
      The old laptop spin up the CPU fan and load the CPU heavily when I move the mouse cursor (in edit mode) so it is obviously trying to do something...
      When I start from scratch everything works as it should, have not gotten to the point where the old skin malfunctioned though…
      Olds69
