help with fusion brain
  • help with fusion brain
    i have just recieved my fusion brain v4 +2temp sensors and accelerometer yesterday, and tried to use the configurator to make a simple test program to test my sensors...
    but it turned out to be not so easy as i thought...
    i have been trying to use the Ninja tool to create a config file for MDX, but when i run it, i get some really strange values:
    as you see i get some strange values both for temp sensors and accelerometer..
    so i tried to use a virtual brain instead, but then i got this fail:
    when i click continue, it reads the sensors value fine and i can see the value om the accelerometer changing when i move it...
    what am i doing wrong?
    bump?
    anyone can tell me why i get theese values??
      after studying the temp function i found 2 mistakes....
      my temp function goes like this:
      input_temp
      subtract 4
      multiply by 1000
      divide by 1953
      but after i changed the two values in bold to 0,4 and 19,53 the temperature started to make a bit more sense...
      now i actually can read the temperature, but there is still something wrong cause i get some like 15 digits:
      i tried to divide the final value by 1000000 in the temp function, but without luck...
        Is your computer set up in the US or international?
          it's a US install but all settings (keyboard and regional) are set to danish..
            That's why. PM 2k1Toaster for more info.
              ok, will try that.... thanks for help
                still no answer from 2k1Toaster
                  He's in the hospital. He'll reply as soon as he can.
                    also, i found this:
                    http://www.mp3car.com/vbulletin/fusi...og-inputs.html
                      ohh well then i got my answer... ^^
                      hope bug will be fixed soon
                        Nothing serious I hope...send him a Get Well from everyone on the forums.
                        Thanks,
                        Dan
                          it's not life-threatening at all from what I understand. he should be back soon.
                            Its because the decimal point vs. comma for separating a number is different. I will have to fix it but easiest is to change regional settings to US/Canada or something.
                            1.9in x 2.9in -- 47mm x 73mm
                              well i can live with it for now. but i really hope there will be an update to fix the problem sometime...
