Change the state of a button
  • Change the state of a button
    How would I change the state of a display button with an "if" statement?
    Thank you,
    GadgetBandit
    Thank you,
    GadgetBandit
    Buttons are meant to change the state of things, not be changed externally.
    You can change variable images, or multi-images (made just for this capability really).
    What are you trying to do?
    1.9in x 2.9in -- 47mm x 73mm
      I'm cycling a value with "when" tasks and want a manual off/on button that "appears" to change state when "when" turns on/off the value.
      A transparent button over a multi image!
      "when" and the button set variables
      The output is handled with "if"
      GadgetBandit
        Today I discovered that a button instance for triggering an output, changes state when you have a "when" statement also triggering the same output. After "when" triggers, the button becomes an "off" button until the next "when" cycle. Pretty cool. Exactly what I wanted.
        Thanks,
        GadgetBandit
          Thanks,
          GadgetBandit
          For that to work, you have to make sure your button is "attached" to the digital output.
          If you change it to "detached" that won't happen.
