install failed?
  • install failed?
    I brought my greenhouse computer in and re-installed your software and switched to the new brain. arg!! this is the result.
    If I click Ninja Kitty:
    Any directions?
    Thanks,
    GadgetBandit
    Have you tried to do a full uninstall and then a normal install?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      Did a full un-install. Loaded MDX Only, it worked. Did a full install. My file worked, except the "when" tasks we're hitting. Not knowing if the installation has the most current updates, I told it to update. arg!! Updater started a "flashy" thing, said it was done, and now I'm back to the prior errors. Tomorrow night I try again.
      GadgetBandit
        in your configurator directory, delete the GTR template.
        Run MDX in debug mode so I can see what the error is.
        1.9in x 2.9in -- 47mm x 73mm
          thank you. I have to go be an adult for a couple days and will post the error on Saturday.
          GadgetBandit.
            I started from scratch, but I unplugged the internet before installing, so updater couldn't do its thing. Intalls fine, seems to works fine, except for my "when" tasks. So, I plug in the internet and updater runs. By all the flashing of file names, a number of files are uploaded. Then MDX is broken.
            Below is the text listed in the "Details" dropdown:
            See the end of this message for details on invoking
            just-in-time (JIT) debugging instead of this dialog box.
            ************** Exception Text **************
            System.NullReferenceException: Object reference not set to an instance of an object.
            at Fusion_Control_Centre_UberMDX.MainMDX.UpdateDaGUI( )
            at Fusion_Control_Centre_UberMDX.MainMDX.OnPaint(Pain tEventArgs e)
            at System.Windows.Forms.Control.PaintWithErrorHandlin g(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
            at System.Windows.Forms.Control.WmPaint(Message& m)
            at System.Windows.Forms.Control.WndProc(Message& m)
            at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
            at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
            at System.Windows.Forms.Form.WndProc(Message& m)
            at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
            at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
            at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
            ************** Loaded Assemblies **************
            mscorlib
            Assembly Version: 2.0.0.0
            Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
            CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
            Fusion Control Centre UberMDX
            Assembly Version: 5.0.0.178
            Win32 Version: 5.0.0.178
            CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/Fusion%20Control%20Centre%20UberMDX.exe
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
            System
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
            System.Drawing
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
            Microsoft.DirectX
            Assembly Version: 1.0.2902.0
            Win32 Version: 5.04.00.2904
            CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
            Microsoft.DirectX.Direct3D
            Win32 Version: 9.05.132.0000
            CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3D/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.Direct3D.dll
            Microsoft.DirectX.Direct3DX
            Assembly Version: 1.0.2911.0
            Win32 Version: 9.12.589.0000
            CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.Direct3DX/1.0.2911.0__31bf3856ad364e35/Microsoft.DirectX.Direct3DX.dll
            System.Xml
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
            System.Speech
            Assembly Version: 3.0.0.0
            Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Speech/3.0.0.0__31bf3856ad364e35/System.Speech.dll
            FusionCOM
            Assembly Version: 1.0.0.472
            Win32 Version: 1.0.0.472
            CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionCOM.DLL
            FusionTypes
            Assembly Version: 1.0.0.0
            Win32 Version: 1.0.0.0
            CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionTypes.DLL
            System.Configuration
            CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
            FusionBrain_WinUSB
            CodeBase: file:///C:/Program%20Files/Fusion%20Control%20Centre%20Uber%20MDX%20Edition/MDX/FusionBrain_WinUSB.DLL
            Thanks,
            GadgetBandit
              Did you run it in debug mode?...
                Ok, you are using it in basic mode. That's why it is failing. Make sure you have DirectX installed.
                Run the updater now and the new exe fixes a bug in basic mode when you have an incomplete or corrupt DirectX install.
                Also make sure you reboot. Yes this is important.
                  Booted, it updated, Configurator is fine. Everything "appears" fine but no "when" task. No error messages with debug mode. My files work except for "when", just ignores them. The other machine has no issue with the files.
                  What is Basic Mode and does my ignorance of it, indcate a greater problem?
                  Even though your installation does DirectX 9.0, are suggesting re-installing just DirextX?
                  Lost,
                  GadgetBandit
                    Nothing in the code has changed regarding when
                    If it has been a long time, you might have them on the wrong timer.
                    Basic mode is when it cannot make a DirectX layer. Meaning install is wrong, system is old/incompatible, or just generally wrong. So it draws with GDI+ which is slow and a system hog instead. That's why you got that big red X in your error window.
                    YOu can force basic mode by putting the command line switch of "basicgui". If you are not forcing it, then there is something wrong with the installation or your system.
                    I would uninstall everything. Download a NEW installer. Then install that. Then restart your system.
                      Why I hate computers:
                      Came back today and after the obligatory update . . . everthing works fine! don't know why, don't care. Just glad to have both computers and brains going. The greenhouse and hydroponics thank ya'll.
                      I learned "if" through Configurator, "when" by whinning for a time, what are some of the other goodies?
                      Great product.
                      GadgetBandit
                        Great product.
                        GadgetBandit
                        glad it is working. Sometimes those little gremlins in the computer just want to have fun!
                        Other goodies such as remote web based control and monitoring perhaps?
