when statements
  • when statements
    <when year="XXXX" month="XX" day="XX" hour="XX" minute="30" second="XX">
    any way to substitute a variable?
    <when year="XXXX" month="XX" day="XX" hour="XX" minute="var" second="XX">
    or
    <when "var">
    and if that's possible, how do you concatenate strings?
    Thanks,
    GadgetBandit
    <whens> look like this:
    Code:
            <boolean_operation type="and">
              <parameter1>
                <boolean_operation type="equal to">
                  <parameter1>
                    <variable do="get" name="mpp"></variable>
                  </parameter1>
                  <parameter2>
                    <number>1</number>
                  </parameter2>
                </boolean_operation>
              </parameter1>
              <parameter2>
                <boolean_operation type="less than">
                  <parameter1>
                    <analogue id="SWC" time="0"></analogue>
                  </parameter1>
                  <parameter2>
                    <number>0.2</number>
                  </parameter2>
              </parameter2>
    if mpp==1 && SWC < 0.2 then ...
    I'm definitely not the expert, but I don't think you'll be able to find things like date and string manipulation in the Fusion environment.
    I think a better way would be to do your logic in another program, then have it use the COM interface to trigger digital outputs or whatever it is you're after.
      or
      <when "var">
      Thanks,
      GadgetBandit
      Your when is correct, and it works that way even with "3X" it will be at anything that starts with '3' and so on. As for using a variable, I suppose I could add that, I hadnt thought of it. Luckily I coded it very generically so it should be relatively easy.
      Only problem is the main source is currently broken. I am working on a huge under-the-hood improvement for USB communication, and that means the program is non-functional. Once I get it back up and running, I will add this easily.
      The when "var" wont be possible right now. It is possible, but it will take quite a bit of time, I will add it to the list.
      1.9in x 2.9in -- 47mm x 73mm
