Using the data from a fusion brain sensor in another program
  • Using the data from a fusion brain sensor in another program
    I recently got my fusion brain for with an ultrasonic proximity sensor. i have the sensor working fine. my question is how do i use the proximity data gathered by the sensor in another program
    If the other program is COM enabled you can do it that way. What are you trying to accomplish?
    1.9in x 2.9in -- 47mm x 73mm
      I'm kind of a newb programmer, so i'm not really sure what COM is, but i want to use the ultrasonic sensors as a blind-spot checking system and output the distance of vehicles in the blind-spot to another program that alerts the driver.
        Component Object Model. It is a software interface standard that allows many different programs to talk to each other. Kind of like in the global automotive business English is the default language for documentation. Not everybody will know enough to fully get your point across but there is rudimentary understanding by most parties.
        COM reading:
        http://www.mp3car.com/vbulletin/fb-s...ig-update.html
        At the moment the COM interface will pass commands (turn off, turn on, volume up, key strokes ect.) and analog input values from your sensor 0 to 5 volt readings. The variable data you set up (logic functions) to convert to meaningful numbers (2.63 meters) can not be passed through the COM. Your receiving program will have to contain the formula to convert the data as well as receive the COM input.
          COM reading:
          MDX sends both the analogue values AND any variables in the program through COM.
            Really? Sorry about that, I've read a couple thousand posts the last few days and everybody seemed to be working around this. Can it receive a variable? For example set a target temperature value in RR and have MDX use that number in logic functions (climate control again)?
              This is awesome news
              i am using a vb program as the driver allert system how would i use COM to send the distance values to this program
