Simple logic for numeric variable
  • Simple logic for numeric variable
    What did I do wrong? When an analog input goes over a value (2.45), I want it to subtract that value and multiply by another value (5.8823) otherwise set variable to zero.
    GM 2 bar MAP sensor is 2.45V at ambient pressure. 0 vacuume, 0 boost. Then its 5.8823 PSI per volt.
    If anybody else cares
    My solution was to 2 logics in configurator. First sets a variable to 1 if greater than 2.45, anti-then sets variable to 0. Separate logic does the math and multiplies by first variable to set boost PSI variable. Only issue now is at exactly 2.45 it sets a value instead of zero. 2.449 or 2.451 it is not a problem so I don't think it will ever land on it long enough to display.
      I dont know what's going on with the mp3car forum updates, but I didnt even see this thread.
      Anyways, a logic if/then currently evaluates things on the fly, but does everything until the end.
      So you are getting a true/false answer then subtracting a value from a boolean which is null/false and so on.
      1.9in x 2.9in -- 47mm x 73mm
        Maybe toss in one more up front that checks for equal to 2.45. That would give the effect of saying => 2.45.
        Thanks,
        Dan
          I don't ever get e-mail notifications from this board. As for the logic, I still don't understand. It is working for me now though.
          Tried that. >= check it quit working. A third equal to check broke it as well giving me a flickering result. I did notice whatever function you fiddle with last is moved to the end. The order of the functions can be important.
