eyeR Interceptor PRO for standalone use, or FusionBrain addition
  • eyeR Interceptor PRO for standalone use, or FusionBrain addition
    UPDATED 24-MAY-10
    ***Note: current eyeR pro users should subscribe to this thread to keep up with new features and updates
    eyeR Interceptor PRO now available, here is the Link
    Firmware update utility:.....FLASH_Updater_V1.9.8.zip
    eyeR drivers:....................eyeR_drivers_1_0.zip
    Latest Firmware:...............eyeR_firmware_1_2.zip
    eyeR configuration utility:..eyeR Pro v1.2 setup utility.zip
    Manual:...........................eyeR_PRO_1_1.manual.zip
    Related eyeR stuff: HERE
    Whats new in firmware 1.2
    • Increased servo adjustment performance, added shortcut keys for easy tuning.
    • Added support for MCP4725 I2C 0-5v analog output D/A addon for sensor testing and simulation
      available @ sparkfun.com.
    eyeR PRO Kit:
    1 x eyeR Interceptor PRO
    1 x Dedicated Climate/HVAC IR remote
    1 x IR remote for controlling intercepted outputs
    1 x Complete input harness
    1 x Complete outputs harness
    1 x Complete side entry harness (for PWM and servo connections)
    1 x USB cable
    Final board for the eyeR PRO complete with enclosure
    Click image for larger version
    Here are the two remotes:
    Both remotes have unique code so they can be used at the same time without conflicting with each other.
    Sample VB application that demostrates the eyeR in HVAC mode:
    This example gives you a GUI for for you climate/HVAC when you are not using your remote. Any changes to the HVAC setting using the remote or eyeR are simutaneously reflected on the GUI, so you will always know the current settings of you HVAC.
    Specifications:
    • Slimline design, 70 x 48 x 14.5mm (with enclosure) so you can slide it in anywhere. Right angle connectors to reduce profile.
    • Lower Standby current, approx 2 - 5mA (when device is in sleep mode)
    • Can be used in conjunction with FusionBrain and other output devices if desired.
    • Stand alone operation, device will function before USB port/PC has powered up.
    • Up to 11 intercept-able outputs. On board intercept LED indicates when inputs do not match outputs.
    • On-board transient protection for automotive applications.
    • all inputs can accept 4-15v inputs (level conversion not required)
    • All Inputs/Outputs can be read/controlled via PC respectively.
    • On-board Infra-red receiver for controlling the outputs via remote.
    • 11 Direct relay outputs.
    • Low power mode with remote wake up for when the vehicle is turned off. IR remote control or inputs changes can wake up device.
    • 2 dedicated Pulse width modulation (signal level PWM) outputs with up to 10-bit resolution, that's 1024 steps. This is useful for ultra precise motor/solenoid/dimmer control.
    • 2 Independent Servo drivers (direct connection) with on-board power supply ~6.5v for high torque operation.
    • On board 3-port hub for add-ons.
    • RS232 connection for communicating to other devices.
    • USB Drivers available for Windows, Linux 2.6.x and 2.4.36
    • eyeR and add-ons firmware easily upgradable over USB.
    That is pretty darn spiffy!
    1.9in x 2.9in -- 47mm x 73mm
      I am liking this. The only thing I would like to see are 2 servo outputs. I need 2. One for heat control and one for heater/defroster control. But that is just me. Keep up the good work.
        I will look into a second servo connection. The only thing is that one servo can be directly connected to the board, If two servo's are required I could possible make a splitter cable that enable you to connect two servo's.
        I will let you know soon if I can manage to squeeze in an extra connection for the splitter cable.
        Saying that it also possible to add additional servo ports using an add-on that plugs into the drive-by-wire bus.
          Very interesting - second servo would be great
          If anyone gives me a rev - I give them the Bird
            Is there any way to use the PWM to control a HIGH CURRENT motor, like for an electric vehicle's throttle control?
            Thanks,
            Keyvan
            1997 Mazda Miata, Black
            MiataPC
            In-dash Fabrication
            Current dashboard: http://www.aescarpc.com/miatapc/2
              From my understanding, the accelerator is basically like a variable resistor (fast & accurate A/D sampling required) and the throttle is controlled via a stepper motor. The eyeR can sample A/D but I havent tested how fast/reliable and accurate. The eye does a/d sampling, has the potential to drive stepper motors and high current motors (with the use of the PWM FET module addon)
              So yes, the eyeR is capable.
                Any updates?
                  Thanx for the interest,
                  I know its been a while since a last update.. I have just sent the first batch of PCB's for manufacture. So I hope to have a finished product working in about 2 weeks.
                  A little board modification (for an enclosure allowance) and slight component modification needed to be done.
                    This could be the worst question in the world, but what does this thing do? I read it back when it first came out and I read it again today. Am I the only one?
                    2001 Mustang Convertible Worklog
                    Indigo Custom Frontend (Flash/Delphi)
                    Blog
                    Qube v1.3 Now Available at the mp3Car Store!!!!!!
                    The simplest IO controller you'll ever use!
                      Hmm, I don't think there is such a thing as the "worst" question!
                      To answer you question, the first version of the eyeR interceptor was basically to intercept/control the fusion brain outputs while the PC/fusionbrain was off.
                      for example, say one of you FB outputs was connected to a relay and suddenly your PC shutsdown or wont boot up! How can you control this relay with the FB not working? (since it requires the PC to be on for it to function) If you connect one of the eyeR inputs/outputs in series with this connection, you will be able to take control of this relay again with the use of an IR remote or any RS232 interface, since the eyeR does not need a constant PC connection in order to function.
                      This system can come in very handy for a complete HVAC system which needs to be controlled when the PC fails (say to demist the windows).
                      Though, initially the first version (FB piggy-back) was specifically designed for HVAC systems, the next model has a host of new features/capabilities such as more dedicated PWM and servo outputs, intercept only mode, direct 2-15v inputs (no need for bias resistors) and a drive-wire bus system which allows countless add-ons to be added.
                      What are these add-ons?
                      Well, I don't want to reveal all of them just yet but the one i'm working on now is the RF Transmitter which allows you to have wireless control of mains and 12v devices directly through the FB/eyeR. Just imagine a RF universal remote!
                        Any more news on this product?
                        Hans
                          The "blue" version (eyeR Mini) was tested and I decided to add a 3 port hub for the add-ons and made a few little hardware changes.
                          The new version (now black!!.. i know) is a bit bigger and board has been modified for an enclosure. I actually just received the black (final) boards today but still waiting on some back order components.
                          The two custom IR remote controls have already been produced and now just working on a VB app to configure the device.
                          So there is still a few weeks before release, though I might have to release a limited amount of units before then for a test release and then update firmware as required.
                          I should update my first post soon with what I have done.. I will do this soon
                            Thanks for the update. Do you have any documentation ready on the new board? I am very interested to see if I can use the built-in climate program with my cars climate system.
                            Hans
                              No complete documentation at the moment. Though if you can share a pic and a some info on how your climate works, eg cable driven, electronic or pneumatic. Then maybe I could help.
