We Need More Usb Ports Captain!
  • We Need More Usb Ports Captain!
    Arrrgggg! I just can't seem to have enough USB ports to make everything work!
    I have my mini keyboard, SILABS Radio, Touch Screen, GPS, DVD and 4 external slots.... Can anyone reccomend a good hub?
    One with external power
    www.newegg.com
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
      Most powered USB hubs require 5v, which you can pull from your computer's PSU.
      How about the Wiki?
        Or you can put a separate power supply in the front of the vehicle and power a couple hubs (depending on how many usb devices you need to run).
        Cheers
        BJ
        Leonardo Da Vinci
          This is what I have:
          Battery powered USB hub. Even has a switch to turn battery mode on and off
          http://www.amazon.com/Cyber-Power-Ba.../dp/B0002UQALQ
            From testing i've done to try and find a good hub chipset for OEM implementation, go with belkin. They use a cypress chip that supports MTT (multi transaction translator). Long story short, if you've got 3 usb 2.0 devices each running at different speeds (high speed usb and full speed usb) the MTT will allow each to work at it's given speed whereas most hubs end up splitting the bit rate among the 4 ports. The chip is more reliable and more specifically, when i tested it, i ran it with a 6.5" screen (streaming video over usb) and 2 other devices.
