help
  • help
    ok here goes
    i have a
    celeron 2.6ghz cpu
    512mb pc 2700 ddr memory
    200gb serial ata hdd
    what i am after is advise on what mobo,case,power supply g/c to use also what else i will require
    i want to use it for
    satnav (using bluetooth gps reciever)
    mp3 play back
    divx playback
    i want to run a 4ch amp fro front and rear
    also a 2ch amp for the sub
    plus a video output to run a 10" screen in rear of car
    wifi
    plus any extra's i may think of
    thanks in advance for the replies
    please check the FAQ link at the top in the nav bar. There is a FAQ there that will tell you how to pick your power supply.
    Only you can pick out which mobo you want. I suggest searhching the mini-itx stickey in the hardware forum.
    The case is something you need to decide on yourself as well. Everyone's needs are different.
    Jan Bennett
