what CarPC is suitable for bad roads
  • what CarPC is suitable for bad roads
    Hi everybody.
    month ago and I'm thinking about installing CarPC into my car
    but I'm worried about two things, bad roads and hot climate.
    please advise to go for it or not and if yes what components I should get.
    regs
    Go for it.
    As long as you take care to solidly mount components, the PC should be fine on your bad roads.
    A hot climate needs some consideration. Components that have low power draw will run cooler.
    Adequate cooling for any system is paramount.
    How about the Wiki?
      Originally posted by DarquePervert View Post
      Go for it.
      Thanks for your reply, I've seen systems with fans and fanless , which is better for my case?
      I found that mp3car has some good ready systems but I do care about screen in sunlight and sound quality
      if any one has past experience about high quality components I'd appreciate his help.
        Make sure you get a transreflective monitor. They are better for viewing in the sunlight.
          what brands/modles do you recommend?
            Xenarc and Lilliput, check out the store on this site. Xenarcs will be a bit more money, but a little better.
