Sirius USB Adapter
  • Sirius USB Adapter
    Hope this is the correct forum for this question ...
    I'm looking at MJS's SC-C1 USB Interface for Sirius ... but I have a question ...
    Where does the unit get power from? I see there's an input for a power supply ... but the "What's Included" doesn't list an external power lead ...
    Anyone use this device before? What should I use for power? Does it power off of USB?
    perk03z06
    Windows XP PC
    InTruckPC
    P4 3.0 GHz Hyperthread CPU, 1Gb RAM, 120 Gb Hard Drive, DVD/CD-RW, Centrafuse XLE 1.47, 7" Xenarc, GPS, EV-DO via Samsung i730 ... more coming!
    it's 12 volts, so it's not powered from USB, which is 5v. It can be powered from your computer supply's 12v line, or car 12v power. I don't recognize the connector though. Ask MJS or on their forum about that.
      its a regular 2.1mm power jack. It needs regulated 12v power, so from the PSU is the only option. If you power it from your car it will go kaboom.
      When I bought mine from mp3car a year and a bit ago, it came with a power jack that you need to solder.
      All the instructions are in the manual.
      1.9in x 2.9in -- 47mm x 73mm
        Mitch emailed me ... there's a terminator in that connector when they ship, so I can terminate raw wireand everything will work.
        Thanks!
        perk03z06
        Windows XP PC
        InTruckPC
          Is this the same with the serial cable? Can I connect it to the car directly? I heard that the XM DIRECT can accept unregulated power.
          1X Ainol Novo Flame Tab
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1X 7 inch motorized Screen
          1x Win 7 PC
            No the XMD can accept un-regulated 12V power.
              thats what I said it CAN accept unregulated power.
              4X MK808b
              3x Perixx Touchpads
              3x 7 inch Screens
              1x Win 7 PC
                Haven't seen the SCC1 in with a serial interface ... I think it's just USB.
                perk03z06
                Windows XP PC
                InTruckPC
                  I have the SC-C1 usb adaptor for my SC-H1 receiver and works great.
                    Awesome. That's great to hear. I never used one before ... cool it has no problems.
                    perk03z06
                    Windows XP PC
                    InTruckPC
                      the sc-c1 uses 12v unregulated... all regulation is done inside the SC-C1 Tuner!!!
                      using a SC-C1 on a SC-H1 IS NOT RECOMENED
                      and if powered via THE SC-C1 Interface, damage may occour
                      ie dont mix the home with the car
                      (there is a way to do it... but unless u need optical, dont bother with sc-h1)
                      mitch
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        Yup, the SC-H1 requires 5V. I have a Audigy 2 NX sound card with 1 optical input so I took advantage of the SC-H1's optical out, which is why I went that route. Audio sounds really crisp with it.
                          mitch
                          really? wow. Well now I can power it off the regular car line instead of a wire hanging outside the PC case to it!
