VoomPC-2 and Via SN-18000G
  • VoomPC-2 and Via SN-18000G
    Does anyone know if the VoomPC-2 is compatible with the VIA Sn-18000G? I am thinking about buying the 2. Any infor would be greatly appreciated.
    -Thanks!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    That VIA SN 18000G CPU cooler is huge. My Intel D201GLY2A barely fits inside the voompc-2 case, so if it's any taller than that then definitely not.
    I don't really see the advantage to using this motherboard over the $75 Intel board. It may offer PCI express graphics slot, but that won't do you any good if you use the voompc-2 case. Intel board is faster, fits, and costs much less.
      as per the manual it says that it is only 34.7mm high its just a bit higher than the ram
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
        Looks like you'll have no problem clearing as the intel board's CPU heatsink/fan is 45mm tall.
        http://www.minipc.de/catalog/il/881
          Go with a case from www.mo-co-so.com. Although slightly taller than a voom, it's very rigid and my Intel D201GLY2A fits with plenty of room. The cases are also very close in price.
          03 Accord Sedan CarPC
