Use HU?
  • Use HU?
    Hi.
    How many are using the headunit to control the sound?
    Im am going to install my carpc soon and I dont know if i shell remove the HU or not.
    Can I get a clear sound without the HU?
    Still running mine through the stock headunit(Monsoon(ie rebadged Delco)) - sounds pretty good to me. Will eventually redo my audio system but it is good for now
    If anyone gives me a rev - I give them the Bird
      I pulled my head unit out and havent missed it since. I use an external Sound Blaster Live and run directly to the amp. I briefly attempted to use the headunit, but found that it sounded horrible.
        it's all personal preference. some prefer to keep a HU with their carPC and others prefer a HU-less system...
        yes, you can certainly get "clear" sound without a HU. since an outboard amplifier is generally better quality than the small internal amplifiers inside a HU, your sound may be even better.
        there are pros and cons to each. keeping a HU allows you to keep hardware-based radio and volume controls but may be harder to integrate everything into your dash for a clean look.
        a HU-less system usually forces you to use software based radio, volume, and EQ controls.
        I personally hate software volume/EQ controls. I kept a HU in my previous system, but have gone HU-less for my current system. I compromised by using a 1/2-DIN pre-amp equalizer between the PC and amplifiers.
        whatever you decide, good luck
        F150 Truckputer [1.0] (coming soon!)
        Fusion Carputer [2.0]
        Fusion Carputer [1.0]
          Keep the HU if you can - you'll appreciate it IF the PC breakdown while on a long road trip.
          OLD SYSTEM (DEAD)
          Intel D945GCLF2 Dual Core ATOM
          Lilliput 7" 629GL 2008 LED Backlight
          BU-353 USB GPS Receiver / iGuidance / IGO8
          M2-ATX Power Supply
          RideRunner Front End / Various Skins
          Windows XP SP3
            It all comes how your car dash is setup. If you have room for the monitor and a headunit, then you could keep the hu. But if you only have room for one or the other, then headless.
              very true... as I've had that happen before
              but you can prepare for that by keeping a portable FM radio, MP3 player, CD "walkman", or SAT radio receiver in the car as a backup audio source, in an 'emergency' you can always feed that straight into your amp.
              I use a Pioneer Inno portable XM receiver which is normally connected to my carPC's line-in jack, but one time I had to use it as a direct XM>amp audio source when my carPC wouldn't turn on (it turned out to be a loose pin in my case's I/O power connector )
              I also keep a cheap pocket FM radio in my car as well. in the rare event that my carPC AND amp should fail to work, I will still have some form of audio available. I haven't had to use it yet (at least not in the car ), but it's always there if I need it ...
              I go crazy driving even 1 mile without music, so I stay prepared at all times
