How good is this Carputer?
  • How good is this Carputer?
    Ok I have a 2006 Dodge Magnum SRT8, it has the Can-Bus sytem and I have a Kenwood 8019 HU in there right now, I want to put in a all in one unit and I came across this. Kinda pricey but if its good quilty and will work then thats ok. Has anyone used it? Would you recomend a different one that I havent seen? Please help me out I want a Carpc that I can use as my Audio deck to and have everything under the sun, bluetooth,gps,radio,music, ect ect. Wi-Fi so i Have come here to seek help. Thank you for your help!!
    to the forum, But came across what? While you are at it, try reading http://www.mp3car.com/vbulletin/faq-emporium/. Theirs a lot of info in their to get you started, and my answer alot of questions you may have.
    If you cant DODGE em, RAM em.
      Ok why is it always deleting my post? I posted a Link and it took it away
        This is the one im talking about: RevoSys X300 Double DIN Car PC how good is it?
        Also this one: http://www.mimousa.com/home.asp?dir=products&prod=2823
        What Im looking for is this:
        1: Double Din unit
        2: Has carpc built in
        3: every option like bluetooth,nav, ect ect ect
        4: RCA out puts so I can hook up my amp for my sub.
        5: I have a Can-Bus system and I need to find out how to hook that up so it all works with one of these decks?? will the addaptor I have for the Kenwood work?
          Ok this is ****eing me off. I cant post anything?
            It's new member restrictions.
            Your post have either a link or photos, or both, and are flagged for moderation and don't show up.
            How about the Wiki?
              Dumb!!!! how do i post that then??
                Reply to your PM, in public for everyone's benefit:
                since I cant post in the fourms can you tell me what you think about This all in one??
                http://www.revo-sys.com/CarPC_Pre-built_Systems.php
                I have a 2006 Magnum SRT with the can-bus system. How much do you know about carputers? Thank you for your help
                I like to think I know quite a bit, as I've been involved with the hobgby for a number of years.
                However, I have no experience with in-dash all-in-one units, other than the little bit of hands-on with the Infill G4, which I think is pretty much garbage.
                From the users that have, I've seen nothing but issues, mostly with build quality.
                The amplifier would be mediocre, at best.
                You can get a comparable modular system for at least $500 less, but then you face the task of installing it, which will be more difficult, admittedly.
                How about the Wiki?
                  Im very good at installing stuff, I dont have any fear for that. You seem to know what your talking about. Tell me what I would need to do this:
                  1: Im taking out my aftermarket Kenwood Touchscreen unit
                  2: I want to do the Carcomputer and be able to do pretty much everything, Phone,internet, ect ect.
                  3: I see like Vroom PC and stuff like that but were im lost is this, I have Can-Bus dont know if your up to date with that or not, but since I have the Kenwood unit I already have the PAC by pass unit that plugs into my factory harness so I can put in a aftermarket deck, How do I splice in the speaker wires, Amp turn on ect to the Carpc??
                  What do I need to buy to do this? Thank you for your help.
                    It's all in the FAQs:
                    http://www.mp3car.com/vbulletin/advfaq.php
                    As far as what to buy, there's no set guide, because it all depends on your specific project goals.
                    If you understand how to get a desktop PC to achieve the functionality you seek, then you simply apply that to a vehicle PC. Understand that a vehicle PC is just a PC, only it's in your ride. The only unique piece of hardware is the power supply.
                    How about the Wiki?
                      hummmmmm, well I just need some help with the Audio part.
                        I have a factory amp to my mids, how do I connect that big group of wires in the back to the car pc?
                          It all depends. Do you want to get rid of the head unit 100%, or do you want a PC that simply runs into the AUX of the headunit? If you want 100% PC, then all you need is to buy a new wire harness that would plug into you cars factory harness, that way you do not have to splice into the cars original wire. Once that is done, it would be PC to AMPS, then AMPS to speaker wire on the new harness. I hope this makes sence, Its sometimes hard for me to explain things.
                          1X Ainol Novo Flame Tab
                          4X MK808b
                          3x Perixx Touchpads
                          3x 7 inch Screens
                          1X 7 inch motorized Screen
                          1x Win 7 PC
                            srtbrian,
                            As DarquePervert said, your post was moderated. It has now been approved and should show up in the thread.
