How do I get rid of the Dual boot screen?
  • How do I get rid of the Dual boot screen?
    I am getting a weird issue when I reformat my PC. I put in the Windows CD, then I erase the partician with my old Windows install and I hit format to NTSF. After all the installation is done when I turn on the PC, before Windows will start to load, I get this message that says "Which Windows installation would you like to load?" Then I have 2 options, the 1 st option always works, the 2nd one I always get an error. So I have to assume my previous install is not 100% being wiped out, but enough that it shows up...... How do I keep this screen from showing up.... Remember this is for a CarPC, so I am using a PS3 thumbpad, so I have to wait for the countdown, which is 28 seconds long, to finish before Windows will start. Anyone have any ideas?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    I believe you only need to edit your boot.ini file.
    Take a look at the file, it's quite self explanatory.
    http://support.microsoft.com/default...b;en-us;289022
    dsatx in voompc 2 case <HERE>
      1. Right-click My Computer, and then click Properties.
      2. On the Advanced tab, click Settings under Startup and Recovery.
      3. Use the pull down menu to select which OS you want to be the default to boot.
      4. Remove the circled tick mark from "Time to Display List of Operating Systems".
      5. Click OK and you are done.
      Click image for larger version
      The Car 2005 Scion xB
      The Truck 2004 GMC Canyon
        Thanx guys, this is great....
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1x Win 7 PC
          crap, crap, crap...
          Had the same prob and instead of looking for the simple solution. I reformated the HD (ntfs SLOW) and prob went away. LOOK BEFORE YOU LEAP.
          For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
            I have always used NTFS slow. Just to make sure everything was wiped. Obviously that doesnt matter in all cases, as in mine.
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1x Win 7 PC
