Shopping for SSD, any particular brands?
  • Shopping for SSD, any particular brands?
    I started to have major issues with both CF and data when coming out of hibernation. Basically the PC will freeze and when I restart and ask for a system report, Microsoft tells me that the hard drive is loosing data and is causing a serious system error. It tells me that its just a one time thing (this is my 20th though) or the HDD is failing. I think its the later. I plan to still keep a HDD, but Windows and all programs will go on a SSD. I have to much media and music, and dont have the money to buy a huge capacity SSD drive. What SSD drives do you recommend? Geeze, it seems like I am having to replace everything in my install! Maybe its because my HDD is on a extended SATA cable, there is about 36 inches of cabling between the PC and HDD?
    ALSO, I am reading that if I am using the SSD drive for an OS, I should get a SLC based SSD, rather then a MLC, is this accurate?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    I have been using an OCZ 30GB SSD since December and it has been great. Super fast hibernation resume and even cold boots. I had to condense my music collection for it to fit on there though. I am planning on buying another 60/64GB SSD that will be dedicated to music/video - that will be enough to hold it all.
    But so far OCZ has been great for me!
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
      Thats is also the one that Mo-Co-So sells. I am so keep seeing one that is called Patriot Warp, alot of people have given it great reviews. I dont mind putting music on the HDD, because if the drive craps out, I have a backup image.
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1x Win 7 PC
        The only SSDs with performance faster than a regular HDD are the new Intel drives that came out end of 08. The X-25 E and M. They are branded by some other vendors as well but Intel makes them. Kingston maybe is one of the resellers?
        Anyways, if you are in the market for an SSD, that is the way to go for sure.
        1.9in x 2.9in -- 47mm x 73mm
          Sorry but OCZ have big problems with I/O(Same new Vertex) with small files... Intel is a lot of faster but have problems with controller if you fill it for more than 80%...
            i'm in the process of putting mine together and I would like to do ssd but i was leaning towards one of the ocz drives for os and apps and another drive for just media (music, video, photos)
              Care to elaborate? I don't mean that in a mean way at all, I am just interested.
              And yes, the Intel SSDs are certainly better drives - that's a no brainer. I only went with OCZ for the price tag And so far I am not experiencing any problems.
              1995 AWD Tsi Talon
              Intel D945GCLF
              M2-ATX
              2GB Corsair
              30GB OCZ SSD
              BU-353
              Lilliput EBY-701
              LSX VOID 3.3
                Compare this ATTO test:
                OCZ Vertex 120GB(Which is Faster than 60GB!!!):
                Intel X25M:
                Compare transfers in 4.0 k files
                  From what I understand alot of SSD drives have the small file read issue. They say that turning off certain features in Windows will correct these issues.
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1x Win 7 PC
                    I'll never buy a MLC SSD drive again, too many headaches. SLC SSD is the better way to go.
                      OK, I will go for a SLC then.
                      4X MK808b
                      3x Perixx Touchpads
                      3x 7 inch Screens
                      1x Win 7 PC
                        Intel X25M:
                        Hmm... Gotcha... But the OCZ does do better in most of the write categories, no?
                        1995 AWD Tsi Talon
                        Intel D945GCLF
                        M2-ATX
                        2GB Corsair
                        30GB OCZ SSD
                        BU-353
                        Lilliput EBY-701
                        LSX VOID 3.3
                          OCZ has operating temp of -10*C which is pretty good compared to others.
                            I have a 32gb Patriot Warp SSD. I have not installed it in the car yet but it works great through all my bench testing and I must say that installing windows on that drive went REALLY fast. I couldn't tell you how it hold up in the long run but so far it hasn't flinched.
                              I just finished installing an OCZ Vertex 120GB SSD in my laptop. The drive is extremely fast, even when applying my drive backup.
                              I don't think you need an Intel X25 for a CarPC. You can get a 30GB Vertex for $129. Maybe even cheaper elsewhere. Or go for the older Apex series if they're cheaper. You're not going to be doing that many repetitive writes to disk in your car pc, are you? Instead, what you're worried about is read rates. I can tell you this Vertex I have boots up my Win7 laptop in about 20 seconds, maybe less. I haven't tried hibernation yet.
                              EWF, HORM, MinLogon on XP.
                              Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
                              Win Embedded Std 2011 RC
                              OCZ Vertex Turbo 30GB SSD
                              Lilliput 629 Transflective, WRX Screen Mount
                              BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
                              VoomPC 2
