Stand by mode and Hibernate disappeared
  • Stand by mode and Hibernate disappeared
    I am running a EEE PC with centrafuse front end and P2140 controller. it was there earlier today while i was trying to get everything to setup and now it is gone. has anyone had this happen and any idea how to fix this issue
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
    Probably should call the police and report a stolen eee. Check with the neighbors to see if they borrowed it. Do you have brothers/sisters/wife/husband/kids that could have taken off with it?
    EDIT: Oh sorry, I should really read these thread titles.
    Have you checked in your power settings to see if the standby and hibernate options are still there?
    Tidder
    Try RevFE
    I Wish I could ban people
      options are gone. and the carnetix P2140 can not put it in stand by mode anymore.
        It almost sounds like you lost ACPI functionality... check in the device manager under system devices for either an ACPI device with a yellow exclamation, or see if you're missing ACPI devices all together.
        Tidder
        Try RevFE
          i think it went away after i setup centrafuse fully but not sure.
            Check to make sure your video drivers aren't screwed up. That can make hibernation at least disappear.
            RevFE
            My Shop
              i took out the intel driver because it kept resetting all of my settings that might be it
                That'll do it. You need a video driver for that stuff to work.
                (silly eh?)
                RevFE
                My Shop
                  hmm....now i need to figure how to keep all my settings
                    What settings is a video driver resetting??
                    openMobile - An open source C# Front End (why choose openMobile?)
                    - Always Recruiting Developers -
                    Like what you see? Donations are always welcome
                      the eee pc has a intel drier a system try and regular windows. they all can change the video settings. so when i reboot they confilct and resest
                        Theres a HUGE difference between a driver and a tray app. Just remove the tray app from startup but leave the driver installed. It will either be in the startup folder or in the registry's run key.
                          I know there is a difference they are conflicting with each other
                            He's saying you can remove the tray app without removing the drivers so they don't conflict. This will allow you to keep your standby/hibernate.
                            RevFE
                            My Shop
                              I know i have tried that already. It was running with out the tray and did some searching and said the resolution has to be picked through there. So i found it started it and did not help.
