The carputer works in the room.
  • The carputer works in the room.
    Not in the car, but atleast it works in the room. Still in the installation and completion phase.
    In this picture, I am using a SWF file to have some motion in my desktop. As you can see its the Mitsu logo.
    This picture talks for itself
    The cable here is sitting over the computer that will become my carputer.
    Fully operation touch.
    What im curently listening to.
    My complete carpc setup
    I like it. When does it get put in the vehicle?
    TruckinMP3
    Read the FAQ!
      Hopefully soon enough, I still need a Opus DC to DC psu, and I have been debating with some body work guys at my job, on ways on how to put it into the center console of my car. It hasnt been easy tell ya that.
        Same here is also have a deskcarputer.
        Waiting for the riser card comming in next week.
        More info here----> http://www.gijsje.net
          where did you get that controller? it looks like the ones off of ebay for about 10 bucks
          BossTone74
            Yes its from ebay, I was looking for an ELO touch and I came across this setup. It inlcuded the lcd, Intellitouch overlay, touch controller and lcd inverter for a $150.00 It was a gamble the guy that sold it to me, sold it "AS IS". I emailed him, asking if it did work he said yes, so I bought it, with the "buy it now" option. Not a bad deal IMO.
            Although I have been looking around for a brighter backlight. Any suggestions? I have emailed various companies, but none have any help.
              looks like I have the same one you have from ebay.. I think the guy was selling quite a few of those kits recently. I got mine for $150 too... waiting for the epia mobo to come in to hook the lcd up to...
              How did you wire up the intellitouch controller to your serial port? Like.. the pinouts? I havn't really messed with it much lately since I don't have it hooked up to a mobo yet.. just wondering in advance....
              Cordell
                really dumb question but what is that skin??
                  That would be a bad *** skin written for Winamp 3 by a cool dude name Arby. You can find it here
                  if you click on it...it will save to your comp...
                  BossTone74
                    thanks dude!!
                    -Dustin
                      Here ya go I got this out of the schematics I have.
                      ELO Intellitouch controller 002310 to the serial connector on the computer
                      Code:
                      P2 Touch controller              Serial connector
                      PIN #  Function                           Pin #
                       1  Data carrier detect (DCD)------------> 1
                       2  Data set ready (DSR)-----------------> 6
                       3  Recieve data (RxD)-------------------> 2
                       4  Ready to send (RTS)------------------> 7
                       5  Transmit data (TxD)------------------> 3
                       6  Clear to send (CTS)------------------> 8
                       7  Data terminal ready (DTR)------------> 4
                       8  N/C----------------------------------> 9
                       9  Ground (GND)-------------------------> 5
                       10 Key-------------------------------------->N/A
                      TO check your controller pinouts and other ones, go here for ELO
                      http://www.elotouch.com/support/webt...lrdiagrams.asp
                      And heres the Serial pinout this is a 9 pin serial though
                        Thanks for the pinouts... I didn't know Elo had that diagrams page. I rigged up a cable last night.. not so pretty, but I'm positive I got the wires and everything tied up right. But, when I plugged the serial cable to my computer and hooked it up to 5v, I couldn't get it to actually work. I downloaded the drivers from Elo, and installed it and all.. and in the control utility it says it is connected and working, but when I try to move the mouse or anything, it doesn't do anything, no movement at all. What am I missing? I even unplugged my ps/2 mouse and still the same thing. ???
                        Appreciate it...
                        Cordell
                          So your pointer does not work not even with a mouse connected? hmm wierd. What OS are you running? Also where did you get the 5vDC to run the touch controller? Also look at the led on the controller it should blink at 1Hz.
                            well, with my ps/2 mouse connected or not connected, the serial touchscreen doesn't do anything. I'm in WinXP now... I'll hop over to Win2k and try it in a minute. I'm getting the 5vdc from my computer's power supply.. I tested with a multimeter to find a 5v, then hooked it up... windows seems to detect it and the driver software installed and all.. even says it is working correctly. Just, it isn't...
                            Cordell
                              also, I don't have to have the LED hooked up, right? and the KEY and reset pins? I don't have those hooked to anything... should I just tie the ground wire (pin 8) to my computer chassis?? or does it matter if it's hooked up now that I'm just testing it?
                              thanks
                              Cordell
