Help! My XP disc is damanged
  • Help! My XP disc is damanged
    Hello guys, After taking a long hiatus from the forum due to life issues I have returned with a new project. My problem is my system is now rebooting itself at start-up. I was trying to boot to the disc (xp) but my little crumb snatcher has been using it as a mirror and has ruined it. Any suggestions on where to buy or fix or.....
    Thanks guys
    If you cant DODGE em, RAM em.
    Thanks guys
    If you know someone that has a disc, you can use theirs and use your product key. If I remember, the disc is transferable, but the key is tied to the computer or hard drive.
    Check eBay also for "Windows XP Install disc"
      i usually take note of the cd-key service pack, if possible, and then download the disc from a torrent site(i can never find my disc when i need it). the discs are all generic, and always require the cd key, so i don't think that part is illegal(i believe this would all become illegal when you don't have a legal cd-key that you purchased). you might also be able to request a new disc from microsoft..
      next project? subaru brz
      carpc undecided
        Thanks for your reply Soundman,
        But, what is a cd-key service pack? I googled it and came up with something (i think) unrelated to what you are referring.
          actually, now that i think about it, the service pack would be listed on the cd...
          xp has 3, or possibly 4 now(my last xp-cd was a sp3 disc) service packs that windows released-- patch updates in bulk form--to correct bugs in the software.
          it might jsut be easier to try contacting micro$oft..
          carpc undecided
            interesting. Just in case MS is not helpful, is their a way to recover the files off of the hard drive?
              Yes - with another PC and appropriate software.
              Don't tell me you have only a single drive/partition - ie, the C: drive with all your data...
              PS - if partitioned, the non-C: drive should be ok...
                For windows XP Home and Pro, the service pack level does not matter. A CD key for XP Pro will also work with XP Pro SP2 and XP Pro SP3. The only time I've ever seen this as an issue is with VLK keys that have been blacklisted. If doing a repair of XP off the disc, just make sure to service pack back up to where you were before, otherwise quite a bit of windows will be broken. Now doing a repair install of Vista is a different story... and windows 7 will probably follow suit. (With Vista, the disc you use to repair has to match the service pack level currently installed)
                However, what will matter is the type of key you have. You cannot install an OEM copy of XP with a retail key, or vice versa. PM me if you need help locating the correct disc.
                Tidder
                Try RevFE
                  Originally posted by Tidder View Post
                  For windows XP Home and Pro, the service pack level does not matter. A CD key for XP Pro will also work with XP Pro SP2 and XP Pro SP3. ... If doing a repair of XP off the disc, just make sure to service pack back up to where you were before, otherwise quite a bit of windows will be broken.
                  I may be of some assistance as well. I have a copy of almost every type of XP disc you can imagine. (Corporate)VLK, Home, Pro... (I work with many different types of customers, I need these things. )
                  As long as you use your product key, the only thing that matters disc-wise is matching the disc's edition with the one your product key is meant to install.
                  After a 2 year break, I'm back! There are so many new and familiar faces here!
                  New vehicle, new ideas!
                  Chryssi - The Changeling CarPC Project
                    Update:
                    I was able to get the disc to run, during the boot -up I hit F11 (me thinks) and it went to an install screen where I had the option to hit "R" for repair it appears that it loaded some drivers and such then it asks to type "exit" to run windows and the darn things still rebooting. Have I done something wrong?
                        G'day Ram.
                        Download and install this small utility that scans your HDD and locates and displays the product keys for XP & Offise etc.
                        Just copy and paste to a fresh install of XP. if you can get a XP disk.
                        http://www.nirsoft.net/utils/product_cd_key_viewer.html
                        Just tried this util, Shows key for XP, Office & IE.
                        Good luck
                        Barry
                          Originally posted by niss42 View Post
                          G'day Ram.
                          Good luck
                          Barry
                          If you would have read through the entire thread, you would know that his machine isn't booting into windows, making this utility useless.
                          Tidder
                          Try RevFE
                            Must feel good to be a green arse wiper.
                            Re- read your own post No 8
                            Yer a mod! alright.
                            niss42
                              I did, but I'm still not sure how the utility you linked to will help the OP? If he can't boot to windows, how will he run the utility?
                              Collect your thoughts, try again.
                              Tidder
                              Try RevFE
