How to implement CarPC into car audio?
  • How to implement CarPC into car audio?
    Just curious what the preferred method is for this? 3.5mm->RCA plug/converters?
    All of my audio is run through two amplifiers as well (1 4channel and 1 mono), which means 3 sets of RCA's for the audio signal to the amplifiers.
    I have been thinking about this for quite some time and wasn't quite sure how you guys do it.
    Thanks for any help!
    EDIT: Just for the record, I have read the noob guide about this, I'm just trying to make sure that it is the best way to do something like this.
    the easy way is to use 3.5mm-to-rca converters, and then use the onboard crossovers on the amps to control the sound.
    next project? subaru brz
    carpc undecided
