Blue Screen issues in XP (ntfs.sys).
  • Blue Screen issues in XP (ntfs.sys).
    Hey guys, my CarPC has been in my Acura TL since Sept 2007 and I haven't had a single issue with it until recently it started freezing (audio would have a cd "skipping" effect). Sometimes it would come out of it and resume sound like normal, and a lot of the times I get a blue screen. I'm assuming since I haven't changed anything with drivers/config lately, it's going to be hardware related?
    I have ran a full chkdsk and it came up with no issues.. I'm not really sure how to diagnose what is causing it. Sometimes when the PC freezes, I hear kind of a chirping sound coming from the PC. I can't tell if its from the hard drive, or motherboard though. Of course I pulled the PC and ran it for a couple days in the house and it never froze, the day after I put it back in, its freezing again.
    STOP: 0x0000007A (0xC07B9768, 0xC000000E, 0XF72ED836, 0x14B73860)
    Ntfs.sys - Address F72ED836 base at F7298000, Datestamp 41107eea
    Jetway VIA C7 1.5GHz Mini-ITX Motherboard
    Kingston 1GB PC4200 CL4 240 PIN DIMM Memory
    Maxtor 120GB 7200RPM IDE Hard Drive
    M2-ATX PS
    Thanks for any assistance!
    1991 Camaro Z28
    2004 Acura TL
    hopefully you still have your OS install CD (Im assuming XP), as you will have to recover that file from the recovery console. google ntfs.sys blue screen and you will find out how to fix it.
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
      Right click "my computer" and go to manage, then click on event viewer and check system. You should see an error and you can figure out what it is from there(a lot of times with XP it's a driver that you can just dl a new one, with the blue screen a lot of times it's the storage driver)
        I'm with you on the hardware thing Slayer.
        You mention that it did not freeze when you brought it into the house but did once it was back in the car.
        What are you using for power in the house is it the same startup controller as you have in the car or a different supply ? Do you have all the same devices plugged in ?
        Maybe there is something wrong with a connection in the car 12V and once XP starts up a few devices the power drain is too much.
        I had a similar issue with a dvd drive during an install as the usb power was not enough to restart the disc spinning if it momentarily stopped. Powering the drive from a different source fixed that problem.
        VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
        Build 90% Apps 50% Install 10%
          I had the exact same problem, it turned out to be an issue with RoadRunner and iGuidance both trying to access the GPS receiver on the same port at the same time. Once I ran xPort3 to split the port into 2 virtual COM ports and then assigned each program its own port, bingo bango, things were perfect.
          Ampie Case
          256 MB DDR2 PC5400
          Xenarc 700TSV - VGA Monitor
          Intel D945GCLF Motherboard
          M2-ATX-HV
          2005 Honda Civic
            The majority of the time it is an xp driver. If you have an incorrect driver installed. Happened to me all the time with my wireless internet driver.
              Typically when I see this issue in the shop, it's due to a failing hard drive or a corrupt windows install. I would try to run hard drive diagnostics on the drive (let me know if you need help with this), and see what it says.
