Audio Processing
  • Audio Processing
    SO i just put my new car pc. I want to do some basic audio proceing wiht it. I loved the sound output of audio enahncer but i can control the vol from inside RR. What are simple options are out there?
    Mike
    what kind of audio processing are you looking to do?
    next project? subaru brz
    carpc undecided
      Very basic just want to clean up the audio a bit It sounds very flat I was using breakaway bit rr can't not control it's vol I look at a couple of your post like with audio mulch it's a bit over my head.
        to do anything more then what breakaway does would require something like audiomulch, or console(www.console.jp).
        also, not sure on your pc parts, but i didn't have very good luck running AM/console on atom hardware-- the cpu just couldn't handle the extra work very well..
        carpc undecided
          I am running core 2 duo 2.8 with 2gb ram. Audio idt onboard
            ok, your hardware should be fine-- just follow the how-to i posted before-- that will get a basic setup going..
            carpc undecided
