USB Y-Cable with Toggle Switch
  • USB Y-Cable with Toggle Switch
    Hi All,
    I am looking to connect an iPhone and an external hard drive to the USB receptacle that came standard with my 2011 Dodge Charger. The system will not accept the two devices connected at the same time, so I need a Y-cable with a toggle switch so that I can go back and forth between the two devices. I've so far been unable to find a product out there like this. Any advice would be very much appreciated!
    sundevil67
    if your really that desperate for a solution. i would consider wiring up a solution your self.
      I'm not sure that such a product exists. There are USB switches, but they are for sharing a single USB device across multiple computers, but you are looking for the opposite. There are also of course USB hubs that allow you to connect multiple devices to one USB port, but it sounds like you've already tried that and it didn't work?
        Will this do?
        http://www.ambery.com/2x2usb20rosw.html ----> Look on how to hookup diagram half way down page.
        Or if you need more:
        http://www.cablewholesale.com/cgi-bi...FYje4Aod3hlJUA
        Good Luck.
          USB Cable
          Can't use a hub because the software wouldn't support it - unless that hub had a switch that allowed me to 'activate' specific devices...couldn't have them plugged in at the same time.
            I think that might just work! And it won't cost all that much to give it a try. Thanks!
