car PC "TV antenna problem"
  • car PC "TV antenna problem"
    Hello to all forum writers ... I have a question to ask, specifically, I have a problem with a TV antenna to the interior. By testing the antenna with a field meter I found that the PC receives the channel normally off, as soon as I turn on the PC does not receive anything. In your opinion where is the problem? The M4 ATX power supply? or a PC? I tried to shield the houses but nothing has changed. We accept suggestions and advice.
    Someone who uses the TV on car-pc, that solution adopted?
    thanks
    greetings
    Carlo
    I would have to say M4 is your main cause. You should read mickz post about diagnose and remedy for the M4, it is quite detailed and informative. I use a slingbox and stream my digital cable package from home, just make sure you have unlimited data plan. SNO
      I am in Italy. cable tv does not exist, MAX 2GB data plan to consumption (mobile network).
      Where can I find the post mickz?
      thanks for reply.
      CARLO
        Took me a while to find it http://www.mp3car.com/power-supplies...ml#post1494006 It's a long but good read. Good luck SNO
