Pen input software
  • Pen input software
    I'm looking for a software that will allow me to write what I want to a text box like the new Audi cars. Win7 has something called "tablet pc input panel", but I don't like how it works and how it spreads across the screen. I want something that's smaller where you enter one letter at a time. Any ideas? Or how hard is something like that to code?
    Also, what would be the proper search term for this?
    On the windows mobile software ( 5-6.5 ) this is called block recognizer and letter recognizer. All of my devices had that option . i ve never see anyone using it though that includes me .
    handwritten software 6.000.000
    handwritten recognition software 12.000.000
    i would go on the first option for faster result....
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
      They used to call that OCR for optical character recognition, but I have researched it.
        The problem with OCR is when you do a search based on that, or a lot of searches on writing recognition come back, they are softwares that actually analyze handwritten text and convert them to editable text. That's what has me stuck. I was thinking of coding this myself, but I can't find a good/detailed reference point or object engine to work from. So I'm still searching for a software.
          I found a windows object, InkEdit, that I was able to write a small app from. The problem is it works fine with the touchscreen, but with the ergonomic touchpad...which is what I'll usually be using...there is a huge lag when writing a letter which seems to cause the writing not to register. Then if i go into a paint application in windows, there is no lag. Any ideas how to fix this? Otherwise I'd have to search for an actual program.
