Hibernate - Windows XP v Windows ME
  • Hibernate - Windows XP v Windows ME
    Hey all -- I had written a small program that would detect whether or not a laptop was running on a battery on AC ... if it was on the battery it would display a message and go into hibernation mode...
    It worked great on WinME .. but when I upgraded to XP it no longer functions. It will detect it's on the battery, but never goes into Hibernation. I have checked and Hibernation is enabled in the Display settings.
    The program was written in visual basic... Thanks!
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    you're welcome.
    My cars
      Originally posted by jol
      you're welcome.
      bwahahhahaha I laughed so hard at this. HILATIOUS!!
      Although the author of the thread, I guess needs help from the programering gurus of these vast lands of information regarding MP3's a quick question??? shouldnt this go into the software section? sounds like software dont it???
      What im curently listening to.
      My complete carpc setup
        Paste the following code into a module.
        Call anywhere in your program by ...
        ShutDown(shutdownmode)
        where shutdownmode = one of the modes below
        Code:
        'These are your modes....
        Public Const ShutDownComplete = 0
        Public Const ShutDownHibernate = 1
        Public Const ShutDownStandby = 2
        Private Const EWX_LOGOFF = 0
        Private Const EWX_SHUTDOWN = 1
        Private Const EWX_REBOOT = 2
        Private Const EWX_FORCE = 4
        Private Const EWX_POWEROFF = 8
        Private Const TOKEN_ADJUST_PRIVILEGES = &H20
        Private Const TOKEN_QUERY = &H8
        Private Const SE_PRIVILEGE_ENABLED = &H2
        Private Const ANYSIZE_ARRAY = 1
        Private Const VER_PLATFORM_WIN32_NT = 2
        Type OSVERSIONINFO
            dwOSVersionInfoSize As Long
            dwMajorVersion As Long
            dwMinorVersion As Long
            dwBuildNumber As Long
            dwPlatformId As Long
            szCSDVersion As String * 128
        End Type
        Type LUID
            LowPart As Long
            HighPart As Long
        End Type
        Type LUID_AND_ATTRIBUTES
            pLuid As LUID
            Attributes As Long
        End Type
        Type TOKEN_PRIVILEGES
            PrivilegeCount As Long
            Privileges(ANYSIZE_ARRAY) As LUID_AND_ATTRIBUTES
        End Type
        Declare Function SetSuspendState Lib "powrprof.dll" (ByVal Hibernate As Long, ByVal ForceCritical As Long, ByVal DisableWakeEvent As Long) As Long
        Private Declare Function SetSystemPowerState Lib "kernel32" (ByVal fSuspend As Long, ByVal fForce As Long) As Long
        Private Declare Function GetCurrentProcess Lib "kernel32" () As Long
        Private Declare Function OpenProcessToken Lib "advapi32" (ByVal ProcessHandle As Long, ByVal DesiredAccess As Long, TokenHandle As Long) As Long
        Private Declare Function LookupPrivilegeValue Lib "advapi32" Alias "LookupPrivilegeValueA" (ByVal lpSystemName As String, ByVal lpName As String, lpLuid As LUID) As Long
        Private Declare Function AdjustTokenPrivileges Lib "advapi32" (ByVal TokenHandle As Long, ByVal DisableAllPrivileges As Long, NewState As TOKEN_PRIVILEGES, ByVal BufferLength As Long, PreviousState As TOKEN_PRIVILEGES, ReturnLength As Long) As Long
        Private Declare Function ExitWindowsEx Lib "User32" (ByVal uFlags As Long, ByVal dwReserved As Long) As Long
        Private Declare Function GetVersionEx Lib "kernel32" Alias "GetVersionExA" (ByRef lpVersionInformation As OSVERSIONINFO) As Long
        'Detect if the program is running under Windows NT
        Public Function IsWinNT() As Boolean
            Dim myOS As OSVERSIONINFO
            myOS.dwOSVersionInfoSize = Len(myOS)
            GetVersionEx myOS
            IsWinNT = (myOS.dwPlatformId = VER_PLATFORM_WIN32_NT)
        End Function
        'set the shut down privilege for the current application
        Private Sub EnableShutDown()
            Dim hProc As Long
            Dim hToken As Long
            Dim mLUID As LUID
            Dim mPriv As TOKEN_PRIVILEGES
            Dim mNewPriv As TOKEN_PRIVILEGES
            hProc = GetCurrentProcess()
            OpenProcessToken hProc, TOKEN_ADJUST_PRIVILEGES + TOKEN_QUERY, hToken
            LookupPrivilegeValue "", "SeShutdownPrivilege", mLUID
            mPriv.PrivilegeCount = 1
            mPriv.Privileges(0).Attributes = SE_PRIVILEGE_ENABLED
            mPriv.Privileges(0).pLuid = mLUID
            ' enable shutdown privilege for the current application
            AdjustTokenPrivileges hToken, False, mPriv, 4 + (12 * mPriv.PrivilegeCount), mNewPriv, 4 + (12 * mNewPriv.PrivilegeCount)
        End Sub
        ' Shut Down NT
        Public Sub ShutDownNT(force As Boolean)
            Dim ret As Long
            Dim flags As Long
            flags = EWX_POWEROFF
            If force Then flags = flags + EWX_FORCE
            If IsWinNT Then EnableShutDown
            ExitWindowsEx flags, 0
        End Sub
        'Restart NT
        Public Sub RebootNT(force As Boolean)
            Dim ret As Long
            Dim flags As Long
            flags = EWX_REBOOT
        End Sub
        'Log off the current user
        Public Sub LogOffNT(force As Boolean)
            Dim ret As Long
            Dim flags As Long
            flags = EWX_LOGOFF
        End Sub
        Public Sub ShutDown9X(force As Boolean)
        On Error GoTo ShutDown9X_Err
            Dim flags As Long
        Exit Sub
        ShutDown9X_Err:
        msgbox "Error occured in Shutdown Module"
        End Sub
        Public Sub ShutDown(byval SDMode as long)
            'Kill winamp
                If WinAMP_FindWindow Then
                    WinAMP_SendCommandMessage WA_STOP
                    WinAMP_ClearPlaylist
                    WinAMP_SendCommandMessage WA_CLOSE
                End If
            Select Case SDMode
                Case ShutDownComplete
                    If IsWinNT Then
                        ShutDownNT (True)
                    Else
                        ShutDown9X (True)
                    End If
                Case ShutDownHibernate
                    'Go into hibernate, force it, but don't disable wake events
                    'this may need work, I dont know what these wake events are...
                    SetSuspendState 1, 1, 0
                Case ShutDownStandby
                    'enable the shutdown privilege
                    EnableShutDown
                    'on Windows2000: hibernate
                    'on Windows9x/ME: suspend
                    SetSystemPowerState True, True
                    'SetSystemPowerState False, False
            End Select
        End Sub
        Get MediaEngine !!!
        Media Engine Download
          Thanks CarComp .. I'll try that out later tonight..
          -Brad
          -Brad
          83 mp320i
          99 mp323i
          _________
