power wire?
  • power wire?
    I have 80amps currently going thru my system what gauge of wire should i use i have 8 now.
    you'll be fine with 8 unless your running it more then 20 feet.
    '98 Explorer Sport
    80% done
      it all depends how much watts you are putting out. I have a 8AWG wire running to one of my amps, I touched it and it is heating up. That said crank your system up, then touch the wire. If its extremely HOT, need to upgrade to something bigger, if NOT you are set.
      What im curently listening to.
      My complete carpc setup
        http://www.streetwires.com/products/wireGauge.cfm
        fill in the info...
        ~Mike
        Single Member of the "1000 Post and No MP3 Car" Club
        PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
        2000 Cavalier Z24 [###-------] Only 30% Done ... Still
          excellent rule of thumb, if the wire doesn get hot, its fine
          2005 Mustang GT:
          12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
          want: my stereo actually IN the car
            I only have 40 amps running to my audio and I have 4 gauge that I'm using. That's what was suggested in the owner's manual for my amp and what was recommended by street wires website.
            I've also been told that running too small of a power wire will greatly effect the performance of your amp. Thin wire will act like a bottleneck for the current that should be going to your system.
            - Sony XAV-7W In-Dash 7" LCD
            - Via EPIA 800MHz
            - 256MB SDRAM
            - 40GB HDD
            - Targus Wireless Remote
            - Win 98SE
            See it Here
            or Here (cardomain.com)
              Nice little chart here:
              Cable gauge chart
              (=========-) 99% complete
              AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
              All jammed in external CDROM drive case.
              Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
                genreally its ok to just run your car system for an hour or so and see how hot the live wire gets buy general rule of thumb, always go larger. I think 4 gauge will do you go, I mean spend a few bucks just to be on the safe side.
                Mine needs to be updated.
