Network Problem
  • Network Problem
    Hi,
    Im having problems trying to transfer files from my home computer to the car computer, using a network card.
    The network card from my epia works fine when its at home, hooked to a normal atx power supply, but when i use a opus as power supply on a car its stops working..
    I think it might be a ground issue, is it possible??
    Tks,
    Bruno
    Tks
    how do you know it stops working?
    how have you tested it?
    the only thing you change is the power supply?
    everything else works?
    how much power does your atx supply put out?
    how much does the opus put out?
    maybe research through here also...
    http://forums.viaarena.com/
    current projects
      I just tested with an atx power supply and with my opus. When i use the opus the network card doesnt work, but with a standart power supply it woks perfectly
      Yes...
      Everything, exept the network card
      350 Watts
      90watts, but im using a 2.5 laptop hard disk and a slim cdrom only.
      Thanks, i will try...
      http://forums.viaarena.com/[/QUOTE]
      Tks
