Blue screen of death...
  • Blue screen of death...
    So I did the install, everything is good, then all of the sudden I start getting the Blue Screen of death.....
    The carputer is in my trunk without any fans right now, Is it probable that this is the cause of the blue screen? they seem to be relating
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    seems extremley possible
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
      Nah, I think most people only put fans in there for the soothing noise. They wouldn't have anything to do with BSOD, would they?
        nah the fans are for cooling the back seat passengers, sometimes they get hot with jealousy, ive seen to pretty badly melted seats.
        Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
        Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
        CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
        http://www.no1knows.com/galleries/
          funniest post evar!
          methinks I found a new signature....
          Debt as of 1/1/05: $34,354.48
          Debt as of July 4, 2007: $0.00 explanation
          I'M DEBT FREE!!
          I'm now a reasonably successful gunblogger.
            cadence117,
            Does your motherboard have ability to moitor temp of the cpu and the case?
            If it does, you can use the software that came with the board to monitor the temps and see if there is a heat problem. Another good software is Motherboard Monitor which you can download from http://mbm.livewiredev.com/ I have it run in the system tray. Today it was aproxx 85 degrees outside. After sitting in the sun all day the temp in my trunk was approx 118 degrees. After I fired up my system (and fans) system dropped to 109 degrees for the cpu and 93 degrees in the case. Your system is pretty close to mine, except I use inverter and 300w power supply. What is amazing is that my car pc is running cooler that my home system (case opened).
            Batman
            Batman@TheNewBatcave.com
            www.samshomepage.net
