VW install help needed
  • VW install help needed
    I am looking for someone that has the
    Volkswagen Official Factory Repair Manual on CD-ROM
    Golf, GTI, Jetta: 1999 - 2004
    Jetta Wagon: 2001 - 2004
    http://www.bentleypublishers.com/product.htm?code=va44
    I would like to install my carpc but would like to know the proper way to remove the door sills in my 03 GTI. I will use a DigitalWW indash screen and have the rest of the computer installed in the trunk. I will also do a double din to single din conversion for the head unit.
    If someone has this software and can print to file the relevant pictures for taking apart the door sills and stuff I would really appreciate. Dont really feel like spending 99$ on something that I will not use too often.
    Please PM me if you have this.
    Thanks,
    Migrane
    ... you don't need eyes to see ... you need vision !!!
    I have it.
    The door sills just pop out, there is one screw back by the seatbelt area, which you need to remove those panels to get to. Those should pop out and lift up by the windows.
    PS Spend the money on the book (you can find them for $50-60 new if you look around. try www.parts4vw.com) it will be WELL spent. And get a Vag-Com while you are at it (www.ross-tech.com) That pays for itself in 2 dealer visits.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
      Go the the Golf & Jetta IV forums on vwvortex.com. It's where I found out info on how to rip apart my MKIV Jetta. You can check my install post here: http://forums.vwvortex.com/zerothread?id=1565061
      My Install Thread
      digitaljetta.com
      MKIV VW Jetta
      How do I get sound to my car?
        Originally posted by judoGTI
        I have it.
        I may consider the book I have the Hayes book for my 94 Golf but I hear the Bently stuff is much better. In the interim though I still need this exact information. With regards to the Ross-Tech thing I know its great but it costs quite a lot of cash and my car is still under warranty !!
        Migrane
          Definitely check on vortex.
          The SEARCH there is good, but you have to be patient and read a lot. The info is there but its among heaps of garbage...
          '02 GTI
            could you post some pics of how the in-dash looks in the vw dash, both open and closed? thansk!
              what did you want to remove, i've pulled apart my whole interior, so if you show me what you want to remove, i may be able to help
                check digitalww's install section
