Startup is too fast!!!
  • Startup is too fast!!!
    I have a few programs that run in my tray on startup. Nothing to intensive just so programs I like to have run. One of them requires a live internet connection which I have with cable. However, the program tries to connect to the internet apparently before my computer has gotten its IP from my router. Thus I get DNS errors and stuff.
    Is there a way to delay programs that run on startup? I only need it to delay 2 or 3 seconds. Any ideas? Would moving it into the startup folder do any good (right now it's just enable in msconfig)?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    BTW google only offers programs that do this... I was hoping to do it with a registry hack or something.
    ,./(0)3
      delete its registry startup entry and put it in the start menu starup folder... that may work
        Didn't work.
        ,./(0)3
          There's a way to run a batch file (*.bat), and in that batch file, delay for a little bit, and then run a program.
          Sorry I don't remember the commands off of the top of my head, but it's not very hard.
            Use AutoHotkey, www.autohotkey.com , to create an exe that waits for a said amount of time and then runs whatever program you want. Off the top of my head the script would be something of this nature:
            Sleep, 3000 ;wait 3 second
            Run, FULL_PATH_TO_PROGRAM_YOU_WANT_TO_RUN
            Compile the script and place it in your startup folder. This probably isn't what you were looking for, but it is a solution.
            ________________
            ______ILL.1______
              I made a batch file and tossed that in the startup folder
              Code:
              @ECHO OFF
              ECHO Delaying gNotify start up. Please wait.
              SLEEP 1
              CLS
              ECHO Delaying gNotify start up. Please wait..
              SLEEP 1
              CLS
              ECHO Delaying gNotify start up. Please wait...
              SLEEP 1
              CLS
              SLEEP 1
              CLS
              START "gNotify" c:\gmail\gnotify.exe
              I wish there was a way to trick the file into thinking that I pressed the enter key.
              ,./(0)3
                The SLEEP command won't work unless you download sleep.exe from microsoft.
                ,./(0)3
                  why do you need to press the enter key?
                  肚子笑痛了
                  S60 Install
                    Nevermind, I see your problem, if you make a shortcut to the gmail.exe file and keep in the same folder as the exe and change your batch file to the below it should make the dos window dissapear
                    Code:
                    @ECHO OFF
                    SLEEP 1
                    CLS
                    SLEEP 1
                    CLS
                    SLEEP 1
                    CLS
                    SLEEP 1
                    CLS
                    c:\gmail\gnotify.lnk
                    肚子笑痛了
                    S60 Install
                      Ask the 9 finger monkeys to help you out with a little VB proggy. Shouldn't be that hard (I can do it but will take me a while) for a pro like him.
                      BTW, but the program in the start up folder will run, but may have problem when returnning from hibernate.
                      Y2K Accord Dell GX150
                      EmoRebellion is a SCAMMER
                        Try using this instead of your regular dos box...
                        http://www.commandline.co.uk/cmdow/
                        this option is the one i was talking about:
                        /HID Hides the specified window. Although a hidden window will not be shown on the taskbar, it will still run and may be unhidden later.
                          The DOS window does dissappear. When gNotify does establish a connection it promps me for a username and password, which are stored by windows. I just have to click OK or hit ENTER if its the active window. I was wishing I could make the batch file hit enter
                          ,./(0)3
                            Could you hardcode your IP on your computer to what the router will provide for you to make it more instant?
                            '02 GTI
                            [Routis '04] [Opus 90W] [160GB Maxtor HD]
                            [Lilliput 7" TS] [VIA M10000] [XMPCR]
                            [512MB RAM] [Custom housing]
                            [Deluo GPS Mouse] [E-MU 0404 Soundcard]
                            Progress Meter: [==============|] 99.9%
                              Dont know if this will help but i was bored. It's an app to launch a program after a specified amount of time. Info in the INI.
                              Status: 40%
                              Car: 2006 Scion tC (Buying)
                              CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
                              Screen: Lilliput 7"
                              Power: Carnetix 1900
                              GPS: Deluo GPS
                              Software: nLiteXP, RR, IG, PhoCo
                              XM: XM Direct
                              http://www.chrispuckett.com/mp3car/
