how to change the default setting for winamp?
  • how to change the default setting for winamp?
    So, you know when you put a CD in and XP will ask you what you want to do with it? Then you can check a box that says...do this from now on...
    how do you change that?
    I need winamp to open up when I put a CD in, a sound cd that is....for competition purposes...
    anyone?
    Jan Bennett
    yeah it's easy but i will have to check now - just wanted to get the 1st reply in befor anyone else! (in one of those 'at work and being silly' moods)
    back in a minute
      Right, the answer:
      open my computer, right click on the drive and go to properties and click the autoplay tab
      I would have posted quicker but i got a phonecall about lots of explosive chemicals and had to concentrate
        lol - aighty - I'll try that tonight if I get a chance....I have so many loose ends to tie up before we leave for Padre tomorrow at noon it's insane...=]
        thanks!
        Jan Bennett
          i have winamp open at startup so it would automatically play a cd if you insert it
          99.9% complete.
          http://www.cardomain.com/ride/212327
            lol..........mkay?
            Jan Bennett
              There's a better input plugin to play CD's. It uses the equalizer and will work with the standard and AVS visualizations, and has a few other niceties that escape me at the time. It's at http://www.winamp.com/plugins/details.php?id=546
              On the File Types option in Preferences, check the box that says "Launch Winamp for audio CD's" and you should be good to go. Scouse is on the right track, but his way will only launch the Windows CD player. Checking the box in Winamp sets the file association.
              JW™
              Powered By Sarcasm
              Ranger: Just bought all my replacement goodies
              Expy: Kenwood KDC-X579 from the Ranger; unknown speakers/amp & 10" Earthquake sub, that all came with the truck
                cool - I got the other working
                on the other - I don't need a player that uses the EQ on the computer - I need to keep everything on the computer flat since I'm using a 170 band eq from alpine
                thanks!
                Jan Bennett
