Ground Loop Isolator Problems
  • Ground Loop Isolator Problems
    Problem:
    When I plug in my ground loop isolator inline between my rca's from my soundcard and my electronic crossover on my car audio my inverter freaks out.
    As soon as I try and turn the inverter on it immediately shuts back down and an indicator light comes on that means Power Overload / Low Battery which I know is not the case because the system works fine without the ground loop isolator.
    If anyone else has had this problem please help!
    Montego II Sound Card
    MTX 2 Way Electronic Crossover
    400 W Inverter / 800 W Max
    Earth your case. That should fix it. ie join a wire (reasonable gauge) from the computer ground to the car ground.
    Hope this helps
    Bj
    BjBlaster! Car MP3 & Carputer!
    bjblaster.com
    "The solution to one problem is only the beginning of another"
      Thanks BJ. I attached an 8 gauge ground from my pc to a common ground in my truck and all my noise is gone and I didn't even have to use the ground loop isolator.
      Thanks!
