2 aux devices, 1 aux input
  • 2 aux devices, 1 aux input
    hey guys
    i have an xbox in my car that plays music through the auxillary inputs on my panasonic head unit. Yesterday i got a sony nehd5 20gb mp3 player for excercise and work but i also would like to use it in the car.
    I know the easy way is an fm transmitter, but fm is ****ty. Therefore i need to take 2 aux sets and get them into one. I know there are lots of those little selector boxes, but that may look kinda ghetto, so finally my question comes to this:
    is there any possible circuit (my electronics raent that great) that could let me choose between which device gets played.
    im open to any designs, i have a few of my own, but yeah
    help
    cheers boys
    Progress 50%
    Next Step: Making Enclosure, Hard Wiring PSU
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    there is a simple mixing circuit you can make with a few resistors. They'll just combine the signals, so oyu cna do both at once. I forget the schematic and values though.
      http://www.epanorama.net/circuits/linesum.html
        I don't think he wants to mix them, just select one to play through the aux at a time.
        You can run the signals to a DPST switch and select them that way.
          Wouldn't you want a DPDT switch.
          1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
            yeah, my bad, twas thinkin in mono :P
              oh okay,
              so i would need 2 of these dpdt switches? one for each channel (judging by that diagram)
              thx guys
              Progress 50%
              Thinkpad 1Ghz P3
              256MB RAM
              Lilliput Motorised
              80GB 3.5"
                You should be able to just use one if you connect all the negatives together (grounds). Like this. (Someone correct me if I'm wrong but I believe that you can use common grounds)
                  http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-806
                  Fabricator
