HD clicking??
  • HD clicking??
    This is a weird problem I get sometimes..it seems to happen in the morning when it's cold. I turn on the carputer, it posts and starts windows...midway while loading windows, the hd clicks and then the whole PC just stalls there. If I just turn it off and back on a few more times it will boot up correctly. THis only happens in the car...when I power from a 12V source, nothing happens... Im kinda guessing it's bad connection to the PSU... Anyone had this problem or any ideas how to go about troubleshotting it?
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    im guessing that the power is the problem like you assumed. Unless the HDD doesnt like the colder weather. To make things easier, i guess try another hdd if possible for a week or so, see if things get better.....
    i had this problem once, and only one with my HDD. I would not boot AT ALL, just clicked. Gave it about 10-16hrs (next day) worked fine, and is still working 1.5years later.... i guess it was just way too cold for a HDD that night!
    Project - GAME OVER :(
      i have sitting next to me a 20gb HD that a customer returned in his computer because it wouldnt boot the first time he plugged it in. I tried it and the HD makes a clicking noise on the first boot after you plug it in.... It is weird. Unfortunatly i have to wait for Western Digital to ship me another one.
      Car: 1999 Dark Green Mustang GT Coupe
      Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
      Player: Empeg for now; something custom later.
      www.neotechpc.com - Custom built laptops!
        the thing is that the computer boots...and starts loading windows. Only starts clicking when windows start loading drivers....and I also realized that when my engine is off, the computer boots up fine... only when engine is turned on....could it be noise on the 12V line causing this??
        My TL CarPC ver2
          It sounds like you are getting noise, or your power supply is staring to fail. What is the voltage at the 12V input on the supply when the car is running?
            Im gonna check that first thing in the morning....take my car appart if i have to! this problem is ****ing me off.....im afraid the HD might totally crash if i dont fix this soon...
            It MUST be either noise....or not enough current being supplied to the PSU...bc the puter works fine at home on my 12V bench power supply. I might have to go with a noise filter of some sort....
            My TL CarPC ver2
              What do you mean by clicking...does it sound like the head is searching because of bad sectors, or does it sound like the head is hitting the stops?
              current projects
                It's the same sound the HD makes when u first power it on. It sounds as if the HD lost power and then regained....so it just stops spinning then starts again.
                I checked voltages ...when car is off it's ~ 12.4V and when engine is on, 14.4V. I don't think the problem lies there... I think its noise. Im gonna ave to go to ratshack and get one of those noise filters.
                My TL CarPC ver2
                  Oh yea, that noise...
                  I know WD has some kind of test program you can download to test their drives.
                  Run the thorough scandisk and see if it comes up with errors...a failing drive should (at least when it happens to me) have errors that increase in number.
                  I have had that before...can't remember the outcome...I think that is what I got before the seagate died.
                  current projects
                    I ran the HD check utilities from Western Digital and it didn't show errors.
                    Next thing I am trying is using a different ATA66/100 cable, I am guessing that the cable might be flawed.
                    Maybe someone spot any flaws in my power wiring schematic ??
                    [ 12-27-2001: Message edited by: moahdib ]
                    My TL CarPC ver2
