Carputer on standby when car is off?
  • Carputer on standby when car is off?
    How would that work?
    how long could a carputer stay on standby before the batteries would need charging?
    I believe that would be the best way for a quick startup of the carputer, and to stop it from draining all the battery if left alone for a while, one could set a timer connected to a relay which shuts the carputer down before it deains the battery completely
    my guess.... with a NEW battery maybe 5-6 hours. Mine's gone longer before but i wouldnt risk it. As for the timer you refer to.. you could just buy a uSDC. Thats what i use to control my computers hibernation. Works perfectly too.
    Live mp3Car Facebook Chat
      it's kinda clumsy to do this with a PC. I'm using a laptop so this would work perfectly for me. I don't even need the car battery. It works like this. Car turns off. Latop goes into Standby. After 6 hours or if the laptop battery drops below 30% (arbitrary) which ever comes first, laptop goes into Hibernate.
      iGMon - Integration between iGuidance and Road Runner
      CFX - Skin for Road Runner
        hmm, yes.. what I am doing is researching on the fastest way possible to make a windows install run after the car has been standing for a while
          If you are not looking to have a second battery, you are probably looking at using a laptop. The setup of a laptop is specifically setup for hibernation/standby use. You are going to get much more options with a laptop.
          2000 Subaru OBS
          Dell P3 @ 900 Mhz
          7" Lilliput TS w/DigitalWW in-dash mount
          80GB External HD
          I am Zero Bitrate....
            I use a laptop in my setup and have a remote switched on my dash to turn the laptop on and off. I have soldered the remote wire to the power switch on the laptop's docking station, also the laptop is set on hibernate when it goes off and comes on in about 5 seconds.. Cool huh...
              There's been a LOT of discussion on this here -- search and see what you find -- but I currently suspend to standby on my installed system and it has so far lasted several days without draining the battery. I cut power to *all* periphials, including USB devices, audio, etc. to minimize current draw in standby. I use an Opus 90W with VIA M6000, 512MB memory.
              My $0.02.
                I have mine on stand-by too, and I've left the car for a few days and the car started with no problem.
                Renault Megane...the OEM look
                  a few DAYS in standby? Not possible unless you have two batteries. Which standby? S1, S2, or S3? I assume he means s1 standby. If you mean s3 standby maybe i could see it considering its about the same as hibernation.
                    That's a good point. Mine is S1 (Windows XP default), but I've never tried S3 because I've never had to (see http://support.microsoft.com/default...BLN%5D;841858). Perhaps I will need to when winter rolls around. Instead, I simply use a USB hub powered off the OPUS 12V rail. The only USB device that remains on during S1 is my bluetooth dongle -- because it needs it's own USB host controller to avoid performance issues I connect it directly to the motherboard. I could probably last even longer if I did the registry mod to have XP suspend to S3.
                    But as I said before, there are many, many threads that discuss this...
                      Oh -- and I have only one (small, stock) battery that came with my car. No second battery, no tank circuit. Something like 120 CCA, but I'm not sure offhand.
                        i have my opus taking my computer into standby. i have a kill switch but i accidentally left it on when i went on vacation. 10 days in standby and my car still fired right up. probably wasn't great for the battery but i usually remember to hit the kill switch if i'm not gonna be driving for a few days. i'm using s3 standby...no usb devices are powered. only a light on the mb and the ram are still active.
                        my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
                        wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
                        company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
                          I, too, use the WinXP default standby option for my carputer and I've left it for as many as 5 days without startup problems. I still have my car's stock battery, too. I am pretty sure my GPS and a sound-activated LED are the only things that stay on because my other USB devices run through a powered USB hub.
                          Come to think of it, I should probably put the LEDs through the hub, too.
                          A car without turbo is a car with perpetual lag.
                          My Ride
                          My New Page
                            S3, only the memory remains powered, everything else shutts down.
                              its completely possible for the battery to last days with the pc on standby. i do it all the time. i think its the suspend function. the only thing required is for there to be enough power to keep the memory alive, which is minimal...
