Wiring M1 Power Supply
  • Wiring M1 Power Supply
    My touch screen is going to be wired into the m1 molex connecter for power. For my M1 power supply I was wondering if it would be ok to wire the positive, ground, remote into the wiring where my headunit was? Or should I just run new wires from the battery, ground, and find an ignition wire? If so what gauge wire should I use and should I use a fuse and which fuse? Thanks
    2006 Subaru Sti
    Lilliput 7", M10000, M2 PSU, 80GB, DVD ROM/CDRW, Audigy 2 NX
    well the M1 has a 10amp, so you will need that amount... check the fuse box to see that you have at least a 10amp on the original head unit wiring... I think my car had a 15amp in the box... so that is enough...
    as for wiring size you'll need a minimum of 20gauge and this is only for a short run - go bigger for longer distances, but that is if you only plan to run the powersupply/cpu... if you intend to add lights, powered USB hub, etc... you'll need to jump up... 18gauge will limit ya to 16amps, 16gauge will limit ya to 22amps - these are rules of thumb from the Handbook of Electronic Tables and Formulas
    http://www.powerstream.com/Wire_Size.htm
    EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
      I have a roll of 18 gauge speaker wire from radio shack http://www.radioshack.com/product.as...t%5Fid=278-008 that I bought a while ago. Will this be ok to use? So I would put a 16 amp fuse between this.
      2006 Subaru Sti
