Ground noise in system
  • Ground noise in system
    I've got an old receiver I have modified into a carPC, I currently am powering this system by a power inverter (might I add is a complete waste of energy). I threw this system in my 02 camry, jack everything in, works fine. the problem is when the car is on, I have alternator whine through the speakers. I have made previous generations of carPC's in my other vehicles and I have always stressed to myself "ground everything" (pretty much), and the typical way I solved alternator whine was to ground the audio signal before it goes to my alpine deck to the frame of the car, usually that works. Except in the camry, when I ground the system, I get MORE noise and TONS of noise lines on the TVIEW monitor. I have also thrown this same system in my 91 full size blazer, no issues with that.
    If I just break down and get a DC-DC PSU would that solve the noise issue?
    Is the electrical system in the camry so different then the blazer where I would need a ground loop isolator?
    does anyone have any ideas?
    MORE COWBELL.
    I think if you buy a dc-dc psu it will benefit you. It may or may not make the ground loop go away
    2006 Subaru Sti
    Lilliput 7", M10000, M2 PSU, 80GB, DVD ROM/CDRW, Audigy 2 NX
      Switch-mode Inverters generate a hell of a lot of switching noise, which could be one of the problems.
      Grounding the audio negatives from the PC is not a good idea. They use what's called a "floating earth", which is not necessarily 0 volts.
      The best way to do it would be to use an isolation transformer/line isolator. You can get them many places, and work really well.
      Additionally, use a noise filter/suppressor inline with the power input to both the PC and the monitor. That should cure the problems.
        are you the guy from minnesota?..
        I would agree, an inverter will most always make things more sucky, and indroduce that 60hz buzz.
        I made my own ground lift, or "audio isloator" from radio shack parts.. cost around $10 but it worked, and saved some money from using BestBuy's $40 solution. just get 2 audio isolators, as they are mono and use the common ground and I also got 2 audio connectors, male and female so it could be in-line. hope those help.
        Shawn
        Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
          Cool, I work at a tv station with nuthing better to do somtimes, I think I may give that a try today, thanks for the imput
          oh yea, yes I am the guy from MN
          mabie I will not be lazy and fill out myprofile..... nope still too lazy Lol
          MORE COWBELL.
            ahh what do you do there? I do some TV production work.. animation and whatnot.
            you can try mine if you'd like.. as we live fairly close.
            Shawn
              Cool, I do pretty much everything here, from production to managing playback, I suppose my main title would have to be a tech. i.e. right now sitting in the server room full of fans blairing in my ear Lol
              MORE COWBELL.
                Please someone, correct me if I'm wrong, but I've read that inverters also create ~20% overhead in power draw. Just another reason to switch to DC-DC. Also, are all your components sharing a common ground or are they simply connected their nearest ground points?
                  He works in champlin for clarification.
                  Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
                  Unlimited Internet and gps tracking for $6 a month with boost mobile!
                  Carputer 2: www.lmaocar.com
                    One more question, what would explain the same system in the blazer not having issues?
                    MORE COWBELL.
                      well I would say, one of 2 things
                      1) better, newer alternator that intriduces little noise
                      2) better grounding in the veichle
                      better ground overall cna fix these issues .. the ground lift is more of a band-aid solution..
                      Shawn
