2.5" drive help?
  • 2.5" drive help?
    hey all Ive got a frustrating problem here, i have a 2.5" drive enclosure and a 30GB drive inside that I'd like my nlited xp to talk to. I plug the drive in and in computer management, the drive comes up as healthy. In my computer the drive letter wont come up, even if I assign a ketter in disk management. If I click on explore the window pops up and dissapears after a secon. I can see the stuff in the 2.5 drive but I can't click on it. If I click open, from computer management I can see and use the data in the 2.5" enclosure. there is no drive letter.... any suggestions?
    oh yea my XP is on a san disk extreme III cf card and the OS sees it as a removeable drive @ fat32. the 2.5" is a ntfs and logical drive...
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Sorry if you said it and i missed it, but have you tried to run the drive on a computer not running n-lited xp on a flash drive? Does it have the same issue?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      I'm not sure I can do that, XP standard is 1.4GB install the CF card is 1GB. I've tried the drive and 2.5" on a normal computer it works just fine.
      The system board & nLited OS has had a 2.5" drive and enclosure on it before. But not this particular drive and enclosure.
      Via EPIA MII
      512MB RAM
      OEM GPS (embedded)
      nLite WinXP pro on
        sorry i phrased my question wrong, that is what i was wondering.
        that does not make sense to me, I dont know much about n-lited windows, can you try another HD on the n-lited computer to see if it reads any other drives then the 2.5?
        My Install
        Software:
        CFiG v1
        CarShell
        StopWatch
          Fixed./
          Well, I figured out what the problem was. So I'll post for anyone that has this problem in the future.
          Because my OS is nLited and stored on a CF card, i used minlogon an XP embedded component which decreases boottimes (5-10seconds) There's known issues when Minlogon is integrated into XP pro and USB, (minlogon is an XPe component)
          Minlogon was killing my USB external harddrive.
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
