Can you make a minitower pc smaller/worth using?
  • Can you make a minitower pc smaller/worth using?
    Im lookin at minitower pcs as a new way to have a carpc. A little big thooo..... I know you can put a computer into anything but is it worth it to take the minitower components and put them into a smaller case? Can it be done? Im not too sure the size of minitower mobos. Also, can a opus or something like that power a powerful minitower? any help is much appreciated, thanks
    oh, im looking at something like this- http://www.compusaauctions.com/cgi-b...aunbr=64434789
    no one has any info/advice about this? please?
      Yes. I've done it with an older AT style computer. It was a K6-2 on a Baby-AT board. Just use standoffs to screw the mobo down onto your case and make sure to account for air flow. Oh yeah, and an opus should be able to power it. Your board may have an AT power connector instead of ATX. An ATX power supply can be modified to fit an AT but not the other way around.
        cool, thanks a lot
          someone also chopped up a shuttle on here... i think it is in the worklogs... saw it recently. basically he chopped half the height of the box
          Roy
          2005 Range Rover 4.4
            something like this?
            This is an older picture. Right now, that case is painted and my comp, HD, and fan are all installed.
            Take 2 - '03 Audi A4
            macmini with an 8" widescreen (in progress)
            My 2004 Ford Ranger:
            14" LCD w/ custom made aluminum bezel
            Completly custom computer case
            status: Totaled
              Less than half. 3/8 of the original height, to be exact.
              How about the Wiki?
                isnt a shuttle a lot smaller than a minitower to start with it?
                  Yeah. It's like 8"h x 8"w x 11"d (approximate).
                  Check out the final result here:
                  http://www.mp3car.com/vbulletin/showthread.php?t=25380
                  How about the Wiki?
                    damn, darque, that's the first time I've seen your setup. that's awesome... makes me want to find a shuttle
                    But don't take it from me! here's a quote from a real, live newbie:
                    Originally posted by Viscouse
                    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
                    eegeek.net
                      but in conclusion....a minitower pc is NOT a shuttle and probably has a much larger mobo so it would be much tougher to make it smaller?
                        true. You can still make a reasonable small player with a Baby-AT board.
