1999 Mercury Sable fan switch
  • 1999 Mercury Sable fan switch
    my fan switch does not work when turned to low or medium. It only works on high. I finally got the dashboard out and replaced the switch. Still problem exists. Is there any place on line I could go to get a wire diagram and see how this switch is wired or where the fan motor in located in the vehical?
    Any suggestions would be appreciated.
    Thanks,
    Bob
    I have heard that there is a high and low speed controller on the later fan itself. I would have it looked at or throw in a aftermarket/new one.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
      There will be (i think this is the proper name for it) a resistor inline with the switch wiring. This is the thing that regulates the voltage to the fan thus giving you the different speeds. I had the same thing happen on a Ford Mondeo i used to have, it turned out to be located in the passenger footwell. Strange but true!
      Im an Essex Boy....I cant help it!!
        You are right about "resistor". there is a resistor pack next to the fan motor and usually it attach to the "air hose/pipe" after the blower. It is nothing but a modue with couple "spring" resistor and those "spring" probably broke/blew due to heat/resistant.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          That the one, it was a spring type thing that had broken. It was quite expensive if i remember as well. Typical Ford part, ie it could only be bought new!!!
            I just replaced the one on my fiance's 98 honda civic..it was $28 at the stealership...took me about 2 minutes to replace it
            As of 4/15/06: Computer is in and running great! Still got a few bugs to work out tho
            M10000, Lilliput, M1-ATX, Slot DVD, 40 GB HDD, 512 MB DDR, BU-353, M$ S&T '06, XMD1000
