few questions
  • few questions
    ok coming this summer i am going to work on my car. i plan to redo my dash center console, install a computer and work on the engine.
    so here are my questions
    i plan on putting my current desktop pc in my car.
    i have this power inverter 300 watt continuous 600 peak should i use it for powering the pc or should i find somthing else?
    i also have heard that these inverters cause distortion to audio is there away around that like puting the inverter up by the battery?
    how would i go about hooking up the audio from the pc to my car audio?
    that is about all i can think of right now for questions
    thanks in advance
    all of these questions are discussed quite often and available with indepth explanations with a simple forum
    STATUS: Planning / In Progress / Completed
    COMPLETE: [*********] 100%
    CAR: '02 Mitsubishi Lancer OZ Rally
    SYSTEM: EPIA M10000
    GPS: HaiCOMM 303e GPS, Routis 2004
    DISPLAY: 7" Xenarc 700TSV
    POWER: OPUS PW-70a + ITPS Combo
    MISC: DVD, WLAN
      i have used the search and i didnt find what i wanted
      but if you know where the topics are and can point me in the right direction i will be very thankfull
        a good place to start is here: the FAQ's
        http://www.mp3car.com/vbulletin/showthread.php?t=51489
        SYSTEM: EPIA M10000
        MISC: DVD, WLAN
          ok so ive done a lot more reading and looking and i found that my computer is using a 200watt power unit so this lets me use my 300watt continuous 600 watt peak inverter safely...
          i still havent found a good place to put the inverter out of my three locations, under the hood by the battery, in the dash , or in the trunk.
          i may have my wireing figured out
          battery-->inline fuse-->distributor-->power switch-->inverter-->computer
          i am then going to take the power button on my computer and wire it to a location on my dash.
