Usb Screens?
  • Usb Screens?
    Afternoon all,
    newbie here, with just a quick question. Ive got a laptop that ive linked into my head unit in my sx200. This is great, but I have to use the laptop to navigate and only have the laptop screen. Was going to go down route of building a carputer, but having the laptop, there seems little point. What I want to do is install a touch screen in the dash and keep the laptop safely tucked away. Does anyone know if there is a 7" touch screen that will run USB to allow me to navigate the laptop from the screen??
    cheers all
    do you mean just hte touch screen, or the touchscreen and lcd display?
    Current:
    [BMW E46 ///M3 Convertible]
    Previous:
    [BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
      just the touch screen, I should imagine I'll be able to run the display through the VGA on the laptop, though if i can run both through the usb it will be easier.
        I've read on here somewhere that you can get them for 50 bucks or so. have a little fish around!
        Current:
        Previous:
          cheers mate ill have a look around. any idea where to start??
            np. this is where I saw it
            http://www.mp3car.com/vbulletin/showthread.php?t=71325
            Current:
            Previous:
              Originally posted by G600
              Afternoon all,
              cheers all
              as long as the drivers for the touch screen are loaded on your laptop, and you calibrate the 7" screen, you should be all set. Since you will be using the VGA out port on your laptop, this is bacically the same as using the 7" on say your home computer as the primary monitor.
              I see no reason why you will have any problems.
              Good luck.
                so one of these will do what im after then??
                Lilluput 619GL-70NP7" touch screen monitor
                7" widescreen (16:9 ratio)
                High resolution TFT LCD panel: 1,152,000 dots
                Support computer display resolution up to 1024 x 768
                Touchscreen display (USB interface)
                Credit card size IR remote control
                Full function OSD control (Multi-language)
                Computer (VGA) / Video Display
                Power input: DC 12V, Power consumption: 9W
                  ah, so you do want a screen with the touch screen panel
                  have a look here: www.linitx.com for LCD monitors. Also checkout cartft.com
                  there are some others, but those are the ones I mainly use.
                  Current:
                  Previous:
                    yes, this will do exactly what you are after.
                      Cheers mate
                        At first I thought you only want a Touch Panel. That make me wonder, how the hell are you going to use it with the laptop?
                        And then you sound like you need a 7" VGA monitor w/TS. This will work if your laptop have an option to enable the VGA out port as a primary display and custom resolution. Custom resolution is not really needed unless you want perfection.
                        Y2K Accord Dell GX150
                        EmoRebellion is a SCAMMER
