Cant seem to register my cd key for xp!!!
  • Cant seem to register my cd key for xp!!!
    After builing my pc i forgot to enter the cdkey with in the 30 day perio.
    Got distracted with other things.
    Now i cant enter the cd key. It asks me if i want to enter it Yes/ No . But then does nothing.
    Please help!!!
    Another quality post from Dyl.
    Uhm, if it's windows XP you can't install without a CD-Key
    or are you talking about a activation code?
    肚子笑痛了
    S60 Install
      you can try booting to safe mode with command prompt, and then run explorer.exe from the command prompt to get one last chance. Most of the time when that happens, i boot to the command prompt and SYSPREP the machine, and that gives me another 30 days Just note you can only sysprep it 6 times i think. then you are fubar
        plenty of ways round this.... Google for them though as Im sure to get flamed or even banned if I post or PM them here
        My Nissan 200SX @ Silverstone
        NOW SADLY WRITTEN OFF!
        My Car's spec list + pics
        Stealth CarPC fab'ing...
          I wont post the full thing.
          Is the key code i need:
          G3HWK-YV9JR-*****-*****-*****
          Right, then. I'm as thick as 2 very short very thick planks when it comes to things like this.
          I can reach the screen that shows my user name next to a box.
          And its got a (click here to switch of pc) button in the bottom.
          It caome up with a box asking "Do you want to activete this now" "yes" "no"
          I click "yes" and nothing happens.
          How do i do that sysprep thing?
          Thanks lads.
          I am welsh! Think thats a good enough excuse!!
            SYSPREP and you should be able to find something
              Sounds like you have a bigger issue, it should be giving you a activation window, did you do anything funky to the install like n-lite?
              肚子笑痛了
              S60 Install
                Right then!
                Ive just disconected the hard drive. booted up again waited for it to do a little search and in the process of re instaling windows. should let me begin the 30 day thing again? Should'nt it?
                Hope so.
                  google has lots of info on WPA and ways around your particular problem...
                  There are also Key testing/generating programs you can DL. Beware though, nearly all will have some kind of Trojan bundled with them or as ActiveX components on the pages you DL them from...
                    Format and reinstall is probably the easiest way to proceed if you aren't great with windows...
                      Heh, thats a good solution to the problem
                      肚子笑痛了
                      S60 Install
                        Seems to be going ok! Fingers crossed!
                        If at first you dont sucseed, Unplug it and reinstall everything! Now i'll have to find my activation code within 30 days!
                        Doubt microsoft would want to help me!!! any help?
                          Search for WPA crack, and then make sure you never let Windows update install Windows Genuine Advantage cause that'll **** you too
                            also, i have always had trouble trying to activate windows unless its plugged into the internet directly (with a wire to lan or whatever) wireless doesnt seem to work during the activation process... Howeverr, i have noticed that calling the phone number (for activation) is a pretty painless process...
                            nGhost - The FREE Frontend for Linux | Graphics Developer
                            Linux ICE - The Car PC Distro | Team Member
                              Just select the option to activate over the phone and follow the instructions. It's quite painless.
