Is it important to have your screen high in the dash?
  • Is it important to have your screen high in the dash?
    I am contemplating installing my screen very low in my dash. Would people advise against doing this? I guess it would be better for keeping the corner of your eye on the road while changing tunes etc if the screen was higher and it would be better for GPS too. But is it really essential?
    Lots of people have them mounted low in the dash. I would prefer it high myself for the reasons you mentioned.
    I'd also set mine down into the dash to shield it from sunlight and angle it so it points towards the roof to minimize reflections (the bane of touchscreens).
    I'm sort of stuck with the stock radio location because I went with a motorized screen.
    Cheers
    BJ
      The location is all up to you, really.
      Higher up on the dash will make the screen closer to your field of view while driving, meaning your attention is diverted for a shroter period of time. However, glare will likely be worse higher on the dash.
      It all boils down to placing the screen in a location that is comfortable for you to use.
      How about the Wiki?
        If I have an option to mount it high, I would. It's better for field of view and some what "safer" when driving. On the other hand, glare is suck. If you look at OEM installed, almost all screen are up higher in the dash.
        But, most of our installs are stucks to wherever the oem radio location.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          it depends on how your dash is set-up
          for many people, lower in the dash is better, while for others, higher is ideal.
          do you have a picture of the dash in your car since many of us have never seen one in person?
          Jan Bennett
            Having it as low as possible (as low as the shifter) makes it a lot more discrete...
            My project: double indash, Golf IV
            http://www.mp3car.com/vbulletin/showthread.php?p=841754
              I have mine high, it goes above the dash. I like it. Some positives of lower could be no direct sunlight and more stealth. There are positives and negatives to both.
              Sound Stage
              Eclipse|MTX|Infinity
                Get Low
                In the past two fab jobs I did, I tried to put the screen as low as possible.
                That way there's less chance of getting pulled over and being asked lots of questions over nothing.
                Actually, the first time I mounted the LCD, it was so low that in 1st, 3rd, and 5th gears the shift would partially cover the lower portion of the screen.
                To avoid being distracted, I'd suggest using some sort of an external input device along with the touchscreen -- for better and easier familiarity.
                It's also helpful to have some sort of a hand/wrist-rest so you don't have to take your eyes off the road when touching the screen.
                For Sale: Carputer (CarPC) & RCA Y-Adapter
                Newsflash: Take a look at my unsold stuff above, thanks!
                Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
                  I have all mine high. Like other have said it's really all about personal preference and available locations. I built custom mounts for my 10" tablets and for me higher is better for both me and my passengers. Its easier to use the touchscreen, GPS is just a sideglance away, and at the speeds I drive I want my eyes out of the cockpit - I'd be afraid to look down to see the screen. Also since I don't want to add headrest screens for rear passengers, up high its easily readable for all (thought I was gonna admit to watching movies, didn't ya ).
                    Boils down tooo....
                    What works for you!
                    Mine is high on my dash...
                    Pros:
                    Easy to see
                    Can be seen easily from the back seat
                    Easy access for Touch Screen
                    Less blocking it
                    Cons
                    cops are constantly asking questions
                    Glare can be an issue
                    Can take your attention off driving.....
                    and block vision if mounted on dash
                    thats what I have found.....
                    For my next install im leaning toward installing it lower....for my car it would mean less fabrication and less distraction...
                    Brown 2010
                      Right in the middle. Just low enough (I have a Jeep) so that cars behind can't see it. But no lower.
                      Mine is mounted away from the dash on a flip up assembly, so I can point it toward the ceiling to avoid glare and to provide access to climate controls. I *love* being able to point it upwards to avoid glare from the obligatory passenger wearing a white shirt!
                      http://www.jeepmp3.com/
                      CarPC Stolen. Starting over.
                      Ne1 recognize the avatar?
                        That is excellent. Mine is mounted on a slight angle as well so that darn T-Shirt isnt the only thing i see
                        Brown 2010
